396 LT4, Needs TB.HELP! Mono or twin 58mm?
monoblade may be nice but I think that it was made for people with money to buy and brag about it. I would stick with 58mm b/c the hp gain isnt going to make up the price difference.
Hey Show good to see you here!
Back in the day one of the rumors was running a Mono and big boost there was the possibility of bending the blade in the center when you lifted. I never experianced it mind you BUT I can tell you at idle I had 6PSI on the blower side of the throttle body. Never did get around to measuring the spike when they snapped shut.
May just be rumors but with boost all you will really get in return is a NASTY over sensitive throttle operation IMHO![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
BTW I HAVE a AS&M Mono and it is not on my car
Thanks Everyone!
WOW! Well I have a few votes for the mono and a few that say its just not worth the extra money.
Big thanks to all that have gave there input. Guess I will just have to do a bit more digging!
On a side note:
I have read that many people have had problems with the Holly TB. Is the BBK a better unit? I read that the Edelbrock is made by the same people that make the GM TB and they are calabrated too. Does anyone have a good 58mm TB sugestion (Not Holly?)
Thanks
Ross
On a side note:
Thanks
Ross
Originally Posted by FASTFATBOY
Anything you put in front of the head that causes ANY restriction lowers the flow over the whole intake tract, it is not as simple as you say it is. I am building a solid roller 383, Pro Action (RHS) 235's a super vic and a sheetmetal elbow from intakeelbows.com with a Mono blade, anything you can do to lessen the restriction will make power.
Engine Masters Mag did a test with a carb on a 383, from a 650 to a 1200 cfm Dominator on a engine dyno, it made more power with each move upward in cfm, with little or no drawback, know why? Made the heads and intake tract more effecient.
The whole idea is to keep the plenum full, IMO a Monobalde will help on a engine that can utilize it.
David
David
[QUOTE=FASTFATBOY]Anything you put in front of the head that causes ANY restriction lowers the flow over the whole intake tract[\quote]
If your motor isn't utilizing the increase in tb size over the stock than how is it a restriction in the first place? It's not...
Simple stated, it is a necessity? Nah....Is it worth the price tag for most of the run of the mill LT1's being built? Nah....you can definitely find other areas to spend your money and get a better return on investment. They are pretty tho and really cool to talk about when people ask
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
[QUOTE=The Big Show]In actuality it is as simple as I stated it. You hit the nail right on the head when you said:
Maybe with a speed density tune, where the TB is open and no CAI on it. But if its a streetcar with a CAI, filter etc. Anything to help pull in air is a plus. If you have a stock head casting, stock intake 383 I would agree with you.
An AFR 220 or above, LT4 or super vic intake, I disagree.
David
Simple stated, it is a necessity? Nah....Is it worth the price tag for most of the run of the mill LT1's being built? Nah....you can definitely find other areas to spend your money and get a better return on investment. They are pretty tho and really cool to talk about when people ask![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
David
Originally Posted by Rat Raceway
Well I ended up going AS&M Mono.
I know its over kill, but just to nice to pass up.
BRETTINATOR
What do I need to do to do to make this TB work? Getting ready to drop the intake off at my mill guy.
Thanks
Ross
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
BRETTINATOR
Thanks
Ross
Originally Posted by BRETTINATOR
Good decision, it's a plug & play unit, just get your setup track tuned (recommended) or dyno tune would be the next best. You are using an LT4 intake right? If so it'll just bolt up,
Thanks Brettinator!
Yes sir, running an LT4 intake.
So, There is no need to mill out the TB intake ports? I thought I would have to cut out the center. Dont I need to match the mono tb port to the intake? Or just bolt it on? Does the small hole under the intake ports carry coolent? Did you have to plug that hole?
Thanks
Ross
I ran a mono on my 355 and it picked the car up from a twin 58mm. I do spin my car more than most though but I don't feel you can every over tb a car. My stock motor piced up going from stock to a 52mm. My heads/cam 355 picked up going from a 52 to a twin 58mm and then picked up again going from the twin 58mm to a monoblade.
Thanks Brettinator!
Thanks
Ross
Thanks
Ross
Yes you have to cut out the inlet to match the Monobalde, That hole will be plugged when you bolt on the monoblade, I think that hole was for IAC on the factory TB, I may be wrong though.
David
I rest my case.
David
#32
David
David
David
That hole does not get pluged with the mono!
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#33
Thanks Brettinator!
Thanks
Ross
Thanks
Ross
RatRaceway - It does not carry coolant, it's used for the Idle Air Control (IAC), just uses air.
#35
THANK YOU SO MUCH!
AS&M didnt send a gasket with the TB! I guess I will call them up! Thanks for the great info! Just what I needed to know! You Da MAN!![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
#38
I WISH I KNEW!!!!!!!!!!
My Procharger is now more then 3 weeks late and it does not look good!
They said they don't know when it will ship! I guess they are missing parts.
Need the head unit so I can do a test fit and make the mods on the block. So far only one thing has gone perfect, the Strange Rear. They poped that baby out in 2 weeks!
I will post some more pictures when I get going again!
Thanks
Ross
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Thanks
Ross
