Engine bearings
Old Jan 2, 2007 | 10:16 AM
95FbFormula's Avatar
Default Engine bearings
Are going with clevite H-series worth the extra $$. I will not be using the stock crank if it makes a difference.
I just cant deiced if i should go with the H-series or not I don't want to buy the P and need to change my bearing in a year and i don't want to buy the H if i do not have to. I am looking for most reliable and what will take the most abuse.
Old Jan 2, 2007 | 10:41 AM
Ls1Bait's Avatar
I used clevite bearings in my motor. Not sure which ones I used (p or h)
Old Jan 2, 2007 | 05:04 PM
Ari G's Avatar
What are you going to use the motor for,how is the weather where you live,what cranck and rods 4340 ...
Old Jan 2, 2007 | 05:49 PM
Motor/ car will be used for a weekend driver, but will see abuse and some track, crank will be stock cast, rods are forged 4340 6". I will probably just go with the H-series to be on the safe side I might as well build it right the first time lol.
Old Jan 2, 2007 | 07:56 PM
GOaT Cheese's Avatar
Don't ever ever cheap out on the bottom end. What are gonna save? A $100 bucks? It just isn't worht it, just do it right, and do it once.
Old Jan 2, 2007 | 08:29 PM
SStrokerAce's Avatar
The bearings also depend on the radii in the corners of the crank.... most aftermarket cranks need the H series bearings due to the larger fillet radius.
Bret
