lt4 hot cam, or CC306
Old Jan 3, 2007 | 12:57 PM
lt197formula's Avatar
Originally Posted by 96blkform
I ran the cc306 for about a year with LE2 heads and personally IMO it was not much of a DD, it had a decent amount of cam surge below 2000rpm and like stated above comes to life at around 3300rpm or so and you have to spin it high - 6500rpm to see all the power. I did run the cc503 on stock heads before changing to the cc306. To me it was a great cam, I used it as a DD and got good mpg and the power was there from 1500 all the way up to around 6000rpm (did not have any cam surge either). It had a really mean sound too on a 112LSA. It can also be emissions friendly which is also a plus. Car made 335rwhp and 340rwtq with the cc503 with MAC mids, stock heads and a PCM4Less tune.
Just my .02
Yeah I have been running the cc306 for a year and a half now, first half year was with lightly ported heads, then I got heads equivilent to le2 heads. Yes even with an m6, 3.90 gears, and tuning it still has cam surge and doesn't really comes to life until (give or take a few hundred rpms) 3k and pulls like a damn freight train until 6500+. I was going to go with a custom cam more than likely but I couldn't pass up a 1000k mile cam for $150 being a poor highschool student at the time.
Old Jan 3, 2007 | 01:07 PM
JoeliusZ28's Avatar
you wont like the 306 even though it sounds like heaven. youll have NO torque until 3500 rpms which sucks IMO. the thing people dont realize when going with big cams on stock heads is that once you get so big with a cam, the low end power loss starts being more than the top end gain.
Im going with the XE503 (224/230) when funds allow. Ive researched this ALOT during down hours at work, and im set on my choice. This is a very good all around cam which is a bit more potent than a hotcam, but significantly milder than a 306. It makes good down low power, and can rev to 6500 if you want it to. Its availible in a 110,112, and 114 grinds. Im going to go with a 110 lsa because i want it to chop good like you do, so that would be my recommendation. And to further illustrate my point about the uneven gains and losses with big cams, ive heard of 224/230 cars taking down 306 cars on the street. (both having stock heads). i dont know about you but i like my torque
Old Jan 3, 2007 | 01:26 PM
Revelation Z28's Avatar
Just my .02
thats about what i want right there, except ill be at 355 ci when i rebuild with the CC503 and port the stock heads. so what would that be 345-350hp tuned?
Old Jan 3, 2007 | 02:37 PM
93-vr4+transam's Avatar
I have had the 306 cam for a yr. now. I love it, but it isn't really a fun dd car. the brakes go to hell. need to run a vacmuum cannister. will have surging. will lose tq. down low. but there is one thing to fix that. a 3500-4,000 stall. but if I had it to do all over again, I prob. would of went with the cc503 on a 110lsa. I love my tq. and now I miss mine...so in my opinion I would run a 503 cam on a 110-112 lsa. it will be a much better dd cam.
Old Jan 3, 2007 | 03:15 PM
infinitebird's Avatar
I think you need to do a little more research and figure out what kind of setup you want for your car, since the hotcam and 306 are incredibly different and really shouldn't even be considered in a comparison except for totally different applications.
Old Jan 3, 2007 | 03:20 PM
1999ssls1's Avatar
cc306 or a custom grind
Old Jan 3, 2007 | 03:25 PM
rasputin's Avatar
Custom grind.
You get exactly what you want. I dont think I need to sell that anymore.
Old Jan 3, 2007 | 04:46 PM
FAD2BLK93's Avatar
+1 for the 503
Old Jan 3, 2007 | 04:50 PM
pddye's Avatar
I really like my 503. It was the cam that comp cams told me to use with the modifications that I told them i had. I wouldn't have went any other way.
Old Jan 3, 2007 | 08:05 PM
sam95transam's Avatar
you can go like I did...cc305 112lsa
http://youtube.com/watch?v=06u0OQP4tac
not the greatest quality vid, but it gets the job done.
Old Jan 3, 2007 | 09:14 PM
vtec's Avatar
Resident Racing Jerk
Originally Posted by slick1851
Um CUSTOM ONLY!
Im sick of these cams, its like the LT1 world will never amount to anything because this is all they keep going with! CUSTOM CAMS!
just wondering... what does your custom cam'd car run?
Old Jan 3, 2007 | 09:31 PM
  #32
Sgt. Spuds's Avatar
Shirley Temple Drinker
were can I find the cc305 on 112lsa for sale
Old Jan 3, 2007 | 09:41 PM
  #33
12345678910's Avatar
look at the le1 package its only $1200 suppost to be 370to390rwhp
Old Jan 3, 2007 | 09:54 PM
  #34
Sgt. Spuds's Avatar
Decided that I'm going with the cc305 on 112 lsa..
What else is going to be needed, PCM tune? Springs? 150k miles, car runs great, no signs of problems...
Old Jan 3, 2007 | 10:11 PM
  #35
Speed Density's Avatar
hashtagBMW
Pushrods, springs, Retainers, RRs, Lifter Studs, cam, New timing chain or set.
Tony.
Old Jan 3, 2007 | 10:26 PM
  #36
speed_demon24's Avatar
You would like the 503 alot better than the 305, more lope and it will make more power than the 305 at any RPM.
Old Jan 3, 2007 | 10:27 PM
  #37
Tony.
What he said, budget in $1200-1500 for the cam swap.
Old Jan 4, 2007 | 10:37 PM
  #38
Sgt. Spuds's Avatar
can someone explain this 503? Is it a easy daily driver cam?
Old Jan 5, 2007 | 12:00 AM
  #39
JoeliusZ28's Avatar
go back and re-read my post about the 503. to answer your question, it does daily drive well because it makes its power via its high lift. On the other hand, the latter tends to be abusive on valvetrain, so i wouldnt expect the setup to last FOREVER like a stock LT1 would. you cant really expect that with any cam setup though. (a 306 would definitely be worse)
heres a thread with a couple videos so you get an idea of the sound of the 110 grind:
http://www.camaross.com/forums/showt...224%2F230+dyno
(scroll down to find the second one)
Old Jan 6, 2007 | 12:48 PM
  #40
pddye's Avatar
I had 120,000 miles on my motor when i swapped in the 503. With stock heads and manifolds it ran great.
