is this dcr or scr ?
Compression as has been said stock was 10.4, hell the iron head LT1 in the Impala was 10.0 and ran on 87octane per GM specs.
I am running 11.5:1 on my stock shortblock with milled aluminum heads and a thin gasket. Guys with built LT1s are known to go over 12:1 on pump gas for the street with tthe right cam.
I sincerly hope you missunderstood the builder or he read the wrong build sheet or something because if everything you told us sofar is right I think you will endup shy of 480 at the flywheels much less the rear wheels.
piston clearance = .004
ring gap = 18
head cc = 67
bore = 4.030
stroke = 3.75
rocker ratio = 1.5
< I WILL BE CHANGING THIS TO 1.6 FOR SURE!!head degree = 23*
rod length = 6" (eagle H beam)
bearing clearance = .002
yeah i know that is not all of the information need to get the compress i know i still need the piston cc. but i am just trying to get all the information about this motor i can. so again i will call him monday and try to get the rest. he is also a older man, so i think he is forgetful.
missing
piston ring height = ?
deck height = ?
piston cc = ?
any thing else i am missing?
I can get the info from the card and post it up tomorrow.
but here are the specs i know about the cam 516/522 230* 240* @.050 112lsa
i figured the advertised duration should be on this paper... maybe the .344 & .348?
Kenneth HI Performance is the guy that built it
The engine was built to be a DD and it is also my only car. so i told the builder that it had to be a reliable motor. Also it would need to be able to drive from houston to San Antonio (about 2 and 1/2 or 3 hours) if needed to. And i would also like around 450 to the ground. Now i know that 450 to the ground and a DD car is a hard combination. but he told me that he could do it so i believed him. now i am unsure
IMO the guy went too wild on the heads and too conservative on the cam and compression.
The duration of the cam could make for a nice reasonably mild stroker daily driver, just thing you need some more lift and easily another .5 compression increase.
1.7 rockers would push it up into the .59x range which might be a bit much. Think Harland Sharp offers 1.65 which would be more like .57x, with the right springs that might be a good compromise.
