Intake elbow/nitrous questions
I've been wondering where I should install my nitrous nozzle myself. I might go the plate route.
I don't know if you would want to buy my elbow. I had to cut it a bit shorter to work with my SLP intake. It does already have the hole drilled and tapped for the opti vent line fitting though.
Exactly why I do not want to put it in the elbow. I deleted my air pump some time ago, so unfortunately that is not an option. I do not feel like replacing my opti as stated above and the hose is currently just sitting in the engine compartment un-hooked. I need a quick and permanent fix. Any other ideas? Please?
