Its DEAD!
Anyways. I remember the Crank sensor being oil soaked when I changed the pan gasket, so maybe it messed up.
I get in and start it.... Its running fine, just like nothing as usual.
Well before after about 5 minutes it would start wanting to die.
Well I waited, and waited and waited. Nothing, it was still running fine.
So I think to crank up the throttle and see if it starts to die. Nothing. Its revving fine. So I waited longer, still nothing. I get in and crank the throttle again. Nothing.
So I do it again, and I noticed a slight off idle stumble.
Well when I get back from work I am going to see if I can go around the neighborhood, see if anything comes up.
I never noticed how many cool smileys there are
Take the Coil Wire off of the Opti, have someone crank it for a sec and see it if sparks.
I learned this the hard way and went after the opti for no reason.
Any of you guys space that whole piece away from the Head, so it's not directly bolted to the Head and getting hot? I did that, and you notice a difference..the Coil is warm, not hot at all. Before it was to the point you couldn't even touch it.
Just get the ICM tested, most places can test it and its cost? 5-10 minutes of your time.
But it hasnt thrown any codes, so I am going to drive it around the college parking lot until it throws codes or dies then tow it back to my house.
I searched but found Nothing
Here's the link for it over on shoebox.Link
But thanks for the link and the explaination, I was thinking a while back about getting a longer coil wire and just relocating the whole thing. But I never did it.
I started it and it started right up and ran for like a minute, then it died. I started it up and it died, then a third time, and it ran, I let it go for like 20 minutes, let it heat up all the way to regular operating temperature and nothing. I was revving it up and trying to simulate regular driving and nothing. It didnt throw any codes or anything, the only hickup was initially when it was dying.
When the engine cools off I am taking in the coil and the ICM and get them tested, then I will do the ICM cooling mod. and let you gus know what all is going on.
My buddy with the scan tool came by again and told me the codes were P1371, and another code for the MAF sensor, but I dont remember which one. Well I replaced the ICM thinking and hoping that was the problem, but nothing, it didnt work. So now I took of the MAF sensor and I lightly sprayed it with Electric contact cleaner. Maybe it will fix it. Tomorrow I am going to buy a new Crank sensor and pop it in and hope for the best.
But he finally looked it up and he said it was a Distributor timing ignition circuit high res code. So he thought it might be either the crank sensor or the cam sensor, which just my luck would probably be the opti.
Well I pick up the crank sensor today and reinstall my recently cleaned out MAF sensor, so hopefully by tomorrow my car will be roaring again
