4:10 gears
Old Jan 6, 2007 | 11:34 AM
Jabsz28's Avatar
Question 4:10 gears
Just got my gears in today...I went with 4:10s. I have a six speed T-56 ..
Does anybody have any advice on puting them in. thanks!!
Old Jan 6, 2007 | 12:31 PM
camar0corey's Avatar
Yeah, unless you have the proper tools and have done a set before, take it to someone to have them put it.
You can do it yourself but you need some tools that aren't in a everyday tool box.
If you've never done one before and you want to install them, find someone that will help you do it that has done it before.
Old Jan 6, 2007 | 01:26 PM
96capricemgr's Avatar
I have done two sets one turned out perfect the other began to make noise and subsequent attempts have not quieted them and I am a fairly experianced shaedtree mechanic.
This is not a beginers project.
Need a press, bearing splitter, dial indicator, capilers are good to have too, magnetic base for indicator, BIG socket set with tools capable of backing it up, I know on my 8.5" rear the pinion nut is 1 1/4" and you will need air or a BIG breaker bar to tighten the crush sleeve. ultra low ange torque wrench capable of say 1-50 INCH POUNDS measurement beam type works best. Having done it and having a good selection of tools I still consider this to be a full day project figure on a whole weekend for your first attempt and then to maybe have to go back and try again if it makes noise.
Old Jan 7, 2007 | 08:58 AM
tbsimmons's Avatar
I would not do it alone if you never have. Find someone that has to walk you through it. After you have done a few then you learn the tricks. I did my 4.56's adn they are fine, first set. But like Dwayne, I was not a rookie at seeing one apart either.
Old Jan 7, 2007 | 02:33 PM
Disturbed Bird's Avatar
in short terms. take it to a mechanic that knows how
