Overheating question
My question is what this could be, I was thinking it was thermostat related but, im not sure. Any advice would be greatly appreciated.
My question is what this could be, I was thinking it was thermostat related but, im not sure. Any advice would be greatly appreciated.Check your temperature sending unit (driver's side head, between cylinders 1 and 3) and make sure that it is good. I know one day my temp gauge wasn't working, and it turned out the sending unit plug itself had broken.
The low coolant light has been on in my car for weeks. I checked the radiator and the resevior and both are full. I was about to try replacing the coolant level sensor (which I believe is in the radiator just under the cap, next to the battery) but the light actually goes out once in a while, only to come right back on next time I start the car. As far as engine temperature goes, when driving it is pretty much always fine (around 180-190), but when I am stopped in traffic sometimes the temperature starts to climb, as high as just past the 210 mark on the guage. Is that normal for these cars to heat up like that when stopped? If it does that in relatively cool weather I am afraid it might overheat in the summer. From what I am reading here it sounds like air in the system might be to blame, does anyone have any experience with air in the cooling system tripping the low coolant light? Any advice on any of these issues is greatly appreciated.
I've been wondering where the low coolant sensor is at also, mine is bad. My light is on most of the time, sometimes it pops off. They are kinda expensive though. I have a bad low oil sensor also, Low oil sensor is only $25, the low coolant sensor is $65!
