best traction device for my setup???
Old Jan 10, 2007 | 06:44 PM
ty97z's Avatar
Default best traction device for my setup???
i have a 97 z/28 thats going to have 410 rwhp its a m6 with 4.10 gears. i have money to buy something for my traction right now but only one thing right now. what do you think would be the best until i get more money? also my car has been lowered. do you think adj. panhard rod, subframe con. etc.. let me know please!
Old Jan 10, 2007 | 07:09 PM
Ralls's Avatar
Tires
Old Jan 10, 2007 | 07:20 PM
ty97z's Avatar
i'll be running drag radials 315/35/17 but what besides tires?
Old Jan 10, 2007 | 08:08 PM
97Lt1TA's Avatar
lower control arms will make it not wheel hop should help. torque arm. the thing is if you got that much power and you dead hook you are bound to break something in the rear end
Old Jan 10, 2007 | 08:51 PM
the_merv's Avatar
Veteran: Air Force
****, I broke the rear in my car on a motor that didn't have much done to it..
streetwarrior96's Avatar
QA1 shocks @ front springs
Old Jan 10, 2007 | 08:59 PM
Ari G's Avatar
This is my setup,i have about 400rwhp
Adj Tourqe arm,LCA Brackets and adj LSA arms,Adj in 3way Competition engeneering Shocks@rear and MT Drag Radials
You really,really need the LSA brackets to get the lsa geometry right to get some traction
Old Jan 10, 2007 | 09:06 PM
QA1 12 way adjustable Shocks Front/Rear
QA1 300lbs Front Springs
BMR K-Member
BMR Upper/Lower A-Arms
BMR Rear Lower Control Arms (Boxed)
Sphon Crossmember Mounted Torque Arms w/ Drive shaft safety Loop
Also +400 here
