Thoughts on the COMP XFI 230/236
If your looking for larger get a custom grind. IF you dont like to do that go with a GM847 or CC306
If I were you , I would do heads and cam at the same time with a bigger cam if it will not be a DD. Just make sure you have the supporting mods. (bolt ons and Gear and all that. )
i am doing a cam swap with stock heads (stock port/valves that is). am i better off with the other 230/236 cam with more lift?
Love the sound at idle, pulls like a freak on boost...
Cant wait to see what it does with 15ish psi
396 hp throught a bad automatic, haven't gone back now that I have the 6 speed but know the numbers will be better.
Also says its gonna make excellent power on boost; We'll see by the end of the month!
