why me?
Old Jan 16, 2007 | 02:09 PM
97LT1's Avatar
Default why me?
Well I figured I would change my coolant today because i was not sure how much was water and how much was coolant. (slow leak in system) I go to open radiatior valve at bottom and drain it. (keep in mind that half of the plastic tab has been broken off the valve due to it being brittle plastic) I go to tighten it down and think it is tight well it was leaking from underneath again by the valve. I have tried numerous ways to get it to stop leaking. I am sure that it is not cracked. I dont have much to grip to turn on it. I have to have this car running by tommorow because it is my daily driver. I am freaking out now.
The whole point of doing this is it is going to freeze tonight. Now I cant drive my car because of trying to avoid a potential problem.
GM can really suck my ***** for making that valve completely out of plastic.
Old Jan 16, 2007 | 02:27 PM
luckyou03's Avatar
theres suppose to be an oring on it and even with that mine used to leak. I rtved the hell out of it and it stopped leaking.
Old Jan 16, 2007 | 02:50 PM
ls1_doc's Avatar
Yeah and sometimes its the actual tank that it goes into that cracks.
Old Jan 16, 2007 | 03:15 PM
GMRL's Avatar
Go to the parts store and buy another one, cant be more than a couple bucks.
Most are the same size for most cars. Hopefully thats whats leaking and not the radiator itself.
Old Jan 16, 2007 | 03:18 PM
Black02Bird's Avatar
damn man, how about you skitz a little, at least you didnt blow a head gasket or throw a rod... remember, it could always be worse
Old Jan 16, 2007 | 06:18 PM
97LT1's Avatar
Yeah sorry I guess you could call that a rant under pressure. I had no idea they sold those at the parts store. I was just trying to get it done, and it was getting colder and colder. If I did not have a ride to my clinical site tommorow I would miss my orientation which would be really bad.
On a side note it had no grips to get the plug back out, and it was a PITA. I am just tired of all the plastic sometimes. It was 2.70 at autozone.
And your right it could be worse, It just seems like im plagued every time i try to do anything to my car lately.
Old Jan 16, 2007 | 06:30 PM
join the club man, nothing goes smoothly, your buying parts made by the lowest bidder to go on something made by machines produced by the lowest bidder. take a deep breath, grab a beer, scratch your ***** and chill. itll get done. how do you think i feel, i work on helicopters at a naval air station... you wanna talk about some parts that dont quite fit or some cheeply made plastic bullshit... i know all about it, to the tenth degree
Old Jan 16, 2007 | 06:59 PM
GMRL's Avatar
Same thing happen to me when I was doing my water pump and opti last summer. I went to turn it and the plastic just snapped off. My dad always told that when things start to get difficult and you start to get pissed off. Just take a break, grab a drink and cool off(or warm up) before you break somthing. Everytime I do that whatever I was having problems with goes easy when I try it again.
