At WOT car dosent pull for half a second
Old Jan 18, 2007 | 03:36 AM
RaM AiR 97's Avatar
Default At WOT car dosent pull for half a second
Car seems to not pull at 6000rpm for a while and then shifts at any gear . I just resently over hauled the tranny and changed stall anybody has had this problem. Help going to dyno tune next week
Old Jan 18, 2007 | 12:27 PM
C_Rules's Avatar
maybe your cam stops making power after 6k. check the rpm power range on your cam. you're dyno tuner will be able to tell where you cam stops making power and then adjut your shift points accordingly.
Old Jan 18, 2007 | 12:36 PM
the_merv's Avatar
Yea, is there anything done to the Engine? Stock Cam it's going to fall on it's face at 6000 RPM. Also, is it tuned for them RPM's, the Tranny can be adjusted to shift very nicely for them RPM's.
Old Jan 18, 2007 | 11:59 PM
RaM AiR 97's Avatar
have a zz-409 cam from tpis 226 in ex 555lift in ex 3500 stall. In park when i rev the engine it red lines at 6300 or 6600 not sure but doesent do that thing. Dont want to drive all the way to the dyno shop and have him tell me you need to fix something on the tranny. So i dont think it would be the cam. kind of hard to explain but seems like if the tranny may be slipping other friends tell me that need to dyno computer doesent know what is going on at such high rpms
Old Jan 19, 2007 | 06:59 AM
the_merv's Avatar
Could be it needs tune adjustments, or the Tranny is slipping.
Old Jan 20, 2007 | 01:33 AM
RaM AiR 97's Avatar
Has anybody heard of this problem or experienced it
the merv have you heard of this problem
Old Jan 20, 2007 | 01:34 AM
RaM AiR 97's Avatar
sorry about those idiots that didnt tune your car properly
