SBC 18 or 15 degree heads...
Old 01-19-2007 | 02:55 PM
A-man930's Avatar
Originally Posted by Fire67
First if your not going to go over 7200, forget the different valve angle and forget a solid roller... You'd be wasting your time IMHO as both were designed by the aftermarket with racing in mind, and that means 7200+ revs.
There are lots of carb style intakes available for the 18* and 15* heads, you'd just have to convert one to EFI or run a carb. No big deal unless your gonna go sheetmetal which would be $$$$.
Ok, now I know the main benefit of a solid roller is the elimination of lifter float, which in turn allows higher RPMs. But I am more interested in the other benefits that a SR can offer, faster revs, reduced paracitic loss (minimal I know), and that AWESOME lope that only a SR can give! But the different valve angle isn't going to help me in the low to mid range?
I'm looking to build a well thought out daily driver with some serious ***** while keeping my costs reasonable, hence beefing up the stock crank. But I'm willing to spend some extra to stand out from the crowd and to get those couple extra hp. Thanks for the help!
Old 01-19-2007 | 03:03 PM
A-man930's Avatar
Originally Posted by v7guy
I don't think you really comprehend what you're getting into here (I could be wrong). There have been a few guys that have tried, and less that have completed the project. Typically several thousand in parts and labor and they throw in the towel and sell everything.
You can make an off the shelf intake work with some grinding if I remember right. Afterwards you need custom headers, a way to route the steering linkage, valvetrain specific to your project etc. It turns into big money quick.
If your just doing it to do it and have money by all means please do and show us lots of pics. Other than that, there are alot better (cheaper) ways to make the power
Again, the valvetrain isn't a problem. Now the steering linkage issue? I've never heard of that... As for the cheaper ways to make power, I don't really want FI on this car, I may mess around with nitrous eventually, and I'm not too interested in doing a big stroker ($$$, plus bragging rights for beating people with "just a little 355") I'm just brainstorming here guys, all imput is welcome!
Old 01-19-2007 | 07:21 PM
thesoundandthefury's Avatar
Side-by-side comparison of "our" heads vs. SB2's:
12* Intake and 8* Exhaust valve angled weapons of mass destruction.
Old 01-19-2007 | 07:52 PM
A-man930's Avatar
Nice... Buuuut I think using 2.2s would put me a bit out of my price range, lol
Old 01-19-2007 | 09:43 PM
vtec's Avatar
Resident Racing Jerk
if your gonna anny up for a sb2.2 setup, might as well ditch the factory LT1 block and go aftermarket.
having said this, you gotta take a look at the new LSx block. good for 2500hp?!?!
might as well convert over to that since im sure there is going to be some amazing heads available for that in the future.
Old 01-20-2007 | 03:02 AM
A-man930's Avatar
Uhh, I'm not building a race car here... I'm not gonna put friggin' NASCAR heads on my motor, not in this lifetime anyways, lol. But I still haven't had my question answered. Are there any advantages to reduced valve angle heads at reasonable RPMs? I could get a set of bare 18* TFS heads and have someone port them for my small displacement. Again, correct me if I'm completely off base.
Old 01-20-2007 | 03:28 AM
SStrokerAce's Avatar
YES there are, put the port height has to be increased when the angle of the heads is decreased. Shallower valve angles give the port a better shot down the cylinder, and a smaller chamber which can lead to higher compression or better burn.
Bret
Old 01-22-2007 | 03:58 PM
A-man930's Avatar
Someone explain the whole "offset rocker arms/offset lifters." thing to me. And after reading on TFS's page, they made it sound like they were really only for high-rpm applications...
Old 01-22-2007 | 05:55 PM
Offset rockers (shaft mounts) are part of what you need when you widen the pushrod restriction in the intake ports to gain cross sectional area. You couple them with offset lifters so the whole pushrod is moved over.
This is a good picture of what happens (even though it's a MOPAR)
Notice how the intake pushrods and rocker arms are moved away from the intake port?
That is the difference in the lifters.... the one on the left has a centered pushrod cup and the one on the right is a offset pushrod cup.
Bret
Old 01-22-2007 | 10:49 PM
A-man930's Avatar
Ahh, so not really too complicated, just expensive for the shaft-mounts. MOPARs have them factory correct? If only... lol.
Old 01-23-2007 | 01:54 AM
None if this stuff is TOO complicated really, you just have to get the basic ideas well.
Bret
Old 01-23-2007 | 07:58 PM
  #32
A-man930's Avatar
Thanks for the info man But I'm still uninformed as to wether it would be worth the effort on a street-driven 355? So I could have higher compression and a more efficient burn... like how much of a difference are we talking here? Obviously I'll discuss all this with whoever's building my motor when it comes time, I just like brainstorming in the meantime
Old 01-23-2007 | 08:54 PM
  #33
UGotBeaT's Avatar
you'll definately benefit from an 18 degree head if done right. Stay away from the brodix 18x heads..there ok if your on a budget but not worth it, wont make much more power over a good 23 degree head, they use 23 degree valvetrain and you have to use there shitty manifold, but there **** compared to a true 18 degree head like a GM or i guess a TFS are decent to.
Old 01-23-2007 | 11:41 PM
  #34
All depends on your wallet really and how trick you want to go. A 18° setup can be built to be much much better, but then again a 23° RR All Pro can be killer as well.
Bret
Old 01-24-2007 | 12:43 AM
  #35
UGotBeaT's Avatar
Yeh I agree..All pro have the nicest 23 deg heads ever but are very pricey!
Old 01-24-2007 | 03:39 PM
  #36
If your asking about 15-18° heads you ain't real worried about price.
Bret
Old 01-24-2007 | 03:45 PM
  #37
the_merv's Avatar
Originally Posted by vtec
Having said this, you gotta take a look at the new LSx block. good for 2500hp?!?!
That's what I am looking into..
Old 01-25-2007 | 05:09 PM
  #38
A-man930's Avatar
Bret
I was looking at the prices a couple of days ago... when everyting adds up it gets to be quite a bit, lol. Because of that, this may be something I do further in the future, it is intriguing still. I very much so agree with the quote in your signature... brainstorming like this helps me sort out all my ideas.
Old 01-25-2007 | 10:51 PM
  #39
TwoFast4Lv's Avatar
We need a Smiley with some one beating the hell out of a dead horse pointing at the search button
Old 01-25-2007 | 11:40 PM
  #40
buffman's Avatar
Bret
I've never seen a setup like that, but what are those extra fittings for? I take it for coolant routing??? Forgive the stupidity
Quick Reply: SBC 18 or 15 degree heads...
