PCV valve
I really dont think it works that way all the time, pull your Breather Tube off and tell me how much Oil is in it, as well as inside the Throttle Body. Going by what you said, if it sucks Air into the Valve Cover from the Throttle Body, where that Air came in from the Intake, that means that all it has to do is get Air into the Valve Cover, which a little Breather Filter accomplishes. I know you said metered air, but I think it breathes out more than it does in.
--Alan
--Alan
we have a winner!!!!
It's been mentioned time and time again
The hose on the passenger side valve cover that connects to the TB is a fresh air hose. As described in FSM, it will flow both ways. Throwing the above mentioned filter on, allows your TB to remain oil free. I run the exact same on my car, and usually change them out every few oil changes. Keeps my TB clean and spotless.Just remember (Merv I think you and I discussed this a while ago) that the PCV system is designed to be closed. If you were to cap off the port on the TB and throw a breather cap on the valve cover (K&N makes a nice one that actually fits in the stock grommet if you want to put on there) you would be allowing unmetered air into your system, since it's air introduced after the MAF. This can result in messed up blms @ idle, and make idling rough, etc. However it's a hit or mess whether or not your car will compensate for unmetered air but in some cases it won't/
--Alan
on the driver side PCV where on the TB does it go like I said mine is capped off @ both places
I like how this is so simple and we make tons of threads about it aguing.. why dont i just leave it capped it collects all the oil in the PCV valve anyways.... but then it doesnt release pressure...
