pace setter header question???
Old Jan 24, 2007 | 07:39 PM
1lo94's Avatar
Default pace setter header question???
i bought the summitt 3 inch x pipe and the pacesetter headers for my lt1 and i was told the x would slip fit on the headers and the pipe is the exact same size for the x and the headers.....any alternative way to hook them up?????
Old Jan 25, 2007 | 05:44 AM
Armyman2445's Avatar
I have that exact system on my car. I installed myself. It will take some modifying. But for the "slip fit" that you are looking for. I went to Auto zone and bought 2 3in couplers. 3in to 3in. There designed to slip fit over 3in pipe. Thats how I fit the collector and pipe together. The couplers only cost about $2 a peice. And you will have modify the drivers side pipe to fit to the collector. I took a hammer and flattened the top of the pipe a little to clearance the bottom of the body. Other than that. You could take the 2 pieces to and exhaust shop and have them streched a little for probaly about 5 bucks. It will look cleaner, than using couplers.
Old Jan 25, 2007 | 06:55 AM
95FbFormula's Avatar
If you put the X pipe that close you wont much benefit from it. And x pipe it to be placed mid way back were the exhuast starts to loose heat. But onther then that the collecter are a good choice to get rememebr to get the gaskets for the collectors if they dont come with them
