ford injectors 38lbs on LT1
are they rated at 43.5 psi like ours ,and if not what would be our equivalent in lbs
i read on some posts that they fit direct on our LT1s
thanks
Dan
A 24#/HR SVO injector is flow rated at 2.7bar (39.15psi). If you put that injector in an LT1 with a STOCK fuel system pressure of 3.0bar (43.5psi), the injector will flow about 5% higher than it is rated.
(43.5 / 39.15) ^0.5 = (1.111) ^0.5 = 1.0541
The 24# SVO needs an injector constant of 24 X 1.0541 = 25.298#/HR
38 X 1.0541 = 40.0558
