what roller rockers does everyone have?
Tony
do you think this is worth it compared to the lt4 hot cam kit??
High-Performance Hydraulic Roller Kit:
GM 12371042 Hi-Performance Roller Lifter Kit
ARP 7/16" Pro Series Rocker Studs
GM 14011051 Hardened Steel Guideplate
CC1305 Pro-Magnum Rocker Arm 1.6 Ratio
CC7202 Hi-Tech Pushrod Length Checking Tool
Ai 4130 One Piece ChromMoly Hardened Pushrods 5/16" x 7.xxx, .080 Wall Thickness
(For Correct Valve Train Geometry You Must Measure)
Cost - $725
Add a Comp High-Tech Race double roller timing set to any package - $60
As far as the kit, if you're using the stock untouched heads and block, you won't need a pushrod length checker, stock length is fine. Even then, everything in that kit minus the length checker would be $759 or so. Doesn't sound too bad to me since they're all quality parts. Remember, the hotcam kit comes with a cam and a valvespring kit too, though, just no pushrods.
