cost of true duals
Old Jan 30, 2007 | 11:24 PM
97Lt1TA's Avatar
Default cost of true duals
how much did you guys pay for your true duals without the mufflers?
Old Jan 31, 2007 | 06:54 AM
LT1MAN's Avatar
ttt..... i want to know too.
Old Jan 31, 2007 | 07:52 AM
ABA383's Avatar
My stainless 3" set up was $800ish including the mufflers which were $120/each...Thats including the labor, too...It wasn't cheap, but it wasn't too easy either...Those with Spohn cross brace mounted TAs know how it is...The fabricator had to make a custom X pipe to fit in the dip in the Spohn cross brace, and I have front and rear DS loops...and we also used 2 stainless V band clamps ($43/each) for turbo applications on the collector ends of the headers...
--Alan
Old Jan 31, 2007 | 08:45 AM
LT1MAN's Avatar
so lets say if i took my two hooker mufflers into a shop and they were just going to order a pipe kit and weld everything up, how much do you think it would cost? for pipes and labor.
Old Jan 31, 2007 | 10:11 AM
ABA383's Avatar
I guess it all depends on your set up, specifically your TA...If you are running a stock or stock mounted TA it may be much easier...There's been a lot of people on here with the Jegs/Summit X pipe kits and they have had good success with them...I'm sure someone will chime in on the cost for them...Also, leaving out an X or an H will make it much easier too...
--Alan
Old Jan 31, 2007 | 12:26 PM
fergymoto's Avatar
Here is my little list for deciding my exhaust setup that I will build in spring. Something like Alan's is a little out of my reach now that I may be going to a different cam. I have not yet decided on a muffler. I do have it narrowed down to three choices though. Once I build this I will coat it with POR-20. Should come out nice.
X pipe kit (SUM-642130): $94.95
Header reducers (SUM-G4752ID): $16.95
Cutouts (SUM-670137): $$53.90
Tips (FLO-T3030): $29.88
Total minus mufflers: $195.68
With Dynomax Bullet mufflers (WLK-24222): $271.58
With Moroso Spiral Flow mufflers (MOR-94051): $289.44
With Edelbrock SDT 304 Mufflers (EDL-55754): $432.46
All part numbers are Summit part numbers.
Old Jan 31, 2007 | 04:35 PM
lt197formula's Avatar
Torque Tech universal f body 3 inch x pipe - $220ish?
Two Bullet mufflers - $36.99 each
Two 3inch flanges, gaskets and hardware - $25ish I really have no idea too long ago
Labor - Free, me and some friends did all the work in his driveway but then I wanted to have them run over the axle because of how ungodly loud it was in the car soo...
Megz tips - $190 yeah I know they were stupidly expensive but I couldn't find any other 3 inch inlet tips and they look good
Labor to have a shop run them over the axle - $220
So rounded up for shipping $325 for dumps including mufflers and $735 for over the axle and this is not including all the misc crap I ended up replacing at the time because "I figured I might as well while I'm here"
Old Jan 31, 2007 | 05:51 PM
97Lt1TA's Avatar
what about the texas speed true dual kit comes with your pick of muffler for 400 i know its for ls1 but couldnt you make it fit on lt1?
Old Jan 31, 2007 | 08:03 PM
goodrich969's Avatar
X pipe kit-100
mufflers-100ish
So 200 bucks. Im doin all my own custom welding and everything.
Old Jan 31, 2007 | 08:28 PM
LALT1's Avatar
Mine ran me 150$ and that including converting the hookers to slip fit, Hpipe, moved 02 bungs, and turned out nicely and tucked better than my borla did.
Old Jan 31, 2007 | 11:33 PM
97Lt1TA's Avatar
does anyone sell pipes that go after the muffler over the axles to the back of the car to put tips. instead of dumping before the axles i would want to have go all the way back and out the tips
Old Feb 1, 2007 | 12:36 PM
You are going to need the bmr panhard bar, and panhard relocation kit. Then just go to a good muffler shop and they can do it for you.
Old Feb 1, 2007 | 12:55 PM
TransAminal's Avatar
You can get the entire Bassani True Dual Setup for $779 in aluminized steel or $949 for stainless steel. It goes from the headers through an X pipe, and then out the back in the same location as the stock single pipe. Looks like it fits very well from pictures, and it sounds great.
I'd buy that system before paying $1200 for a custom job at a shop, which may or may not fit as well or sound as good, plus you can install it yourself.
Old Feb 1, 2007 | 09:44 PM
Quick96ss's Avatar
They make a X pipe for F bodies?? Where can you buy that from??
