Pics of my catch can setup for you guys wondering how to do it.
Originally Posted by James Montigny
Yup, 93s are different.
I'm trying to figure out how to use a catchcan on mine too.
The manifold is coated in oil inside and it's not helping performance any.
Yeah, my 94 is that way. The line runs from the valve cover to the TB. Then there is a U shaped line from the PCV to the line right next to it. So I am really confused now!
How is that you go from the PCV to the Valve cover? What happens to the opening where the other end of the PCV line once connected and the fitting on the TB where the fresh air line once went?
This makes no since what so ever? Call me an idiot... but im confused.
-bryan
-bryan
-bryan
Valve cover to TB is fresh air hose. that is part of the PCV system, not the PCV itself. On 94 and newer LT1s the PCV valve located in the intake goes into a hard line and comes around to the front of the intake where a nipple is. People install the catch can between that line.
Ok, I got mine working. I thought I would share for the 94's our there. We have that U shaped line from the PCV that dumps right into the intake. I have mine connected in that U line with the direction of flow from the PCV to the intake.
I will get some pics of it later.
-bryan
-bryan
-bryan
-bryan
#32
Originally Posted by WhyHelloOfficer
Why not just do it the way speeddemon has it? Is the PCV system that significantly different from 94 to 97?
After all, mine is working and catching oil from getting into the intake.
-bryan
#35
Ok here ya go.
That amount of oil is after two trips to Charlotte and back. About 200 miles roughly.
So if you take that U shaped line off, you will have the line start from the PCV then go up to the seperator. From the seperator you would go to where the other end of that U line was. It is had to see in the pics. But if you remove that vacuum line from the brake booster you can see both fittings better and it will be easier to mount everything up to.
Hope this helps.
I hate the way the hoses run, doesnt look the greatest IMO. I loved the way I had it routed when it was on the other side, which was wrong. Oh well.
-bryan
Hope this helps.
-bryan
#38
Thanks for the pics Bryan.
How often to do you have to empty that thing?
As for the boosted application, you are on your own there, lol. I have no clue on that stuff really.
-bryan
#39
Ok here ya go.
Hope this helps.
-bryan
Hope this helps.
-bryan
#40
I did have it on the fresh air line at first and I did catch some stuff. However, I found out that the fresh air line flows both way so I took it off. (because the filter was only flowing one direction) If there was a filter that flows both ways, I would try running it.
-bryan
-bryan
