Intake Studs
Old Feb 5, 2007 | 02:44 PM
Phantomhp's Avatar
Default Intake Studs
Ok, so I found the size of all the bolts for my LT1 intake but there are 4 bolts that are stud type.
Are those needed for anything or could I just put regular bolts in their place?
Thanks,
Mike
Old Feb 5, 2007 | 02:59 PM
foggedz's Avatar
As long as you have eliminated the things that mounted off the studs you will be fine. I believe that the alternater bracket mounts to the 2 of the passanger side studs, and I think a coolant line also. On the drivers side part of the egr setup mounts to one of the studs.
Old Feb 5, 2007 | 03:00 PM
LT1MAN's Avatar
doesn't the fuel rail bolt to the top of the studs too?
Old Feb 5, 2007 | 03:31 PM
foggedz's Avatar
I dont think so. The fuel rail bolts to the top of the intake manifold
Old Feb 5, 2007 | 06:29 PM
NotACop97Z's Avatar
He's Right, the largest Stud is for the alterator,
Old Feb 5, 2007 | 08:34 PM
WhyHelloOfficer's Avatar
There is also a stud that holds some of the EGR/AIR equipment in place. One of the studs on the driver's side holds the throttle cables in line so that they line up to the throttle body for the throttle position and cruise control.
Old Feb 5, 2007 | 09:45 PM
The LT1 That Could's Avatar
Hey Mike! I thought about this today...might call Scoggin and see if they have a set of LT1 Intake Bolts, they might have a full kit of the hardware needed.
Old Feb 5, 2007 | 09:58 PM
the_merv's Avatar
Mine has a black Bracket with 3 Bolts to hold them.
