Carnage report
The Ring and Pinion in the Rear are both stripped with chunks of the teeth missing on both, and something in the Transmission is broken, I can hold the Driveshaft while someone is pressing the gas in Drive. It took a hit..
Now I am just sitting back and pricing things out. I might possibly sell the POSI in it now and upgrade to a 12 bolt while I am here cause I have to re-build it anyways. No damage was done to the Carrier or any of them components, if anything it worked very well to kill the Gears. Engine is fine, no damage there. As far as the Tranny, I might build the other motor that I am wanting to do, and get a new Tranny in it, and have that one built up. Then take my LT1, and drop that into something, or sell it.
If anyone has any parts or know where to get them, let me know..
I had a pinion bearing go out a couple years back, I kept hopeing and praying that it wasnt something worse, and finally when I got in there I was so happy just to see the pinion bearing was bad.
Well good luck with the build up, I want a 12 bolt too.
Sorry to hear about your bad luck.
Daren
