918 Springs????
Old Feb 14, 2007 | 10:26 AM
wkniffin98ss's Avatar
Default 918 Springs????
I just bought what I thought were 918 springs and they dont appear to fit, will I have to machine the heads to make them fit or did I get the wrong springs?
Old Feb 14, 2007 | 10:29 AM
Taubr Unit's Avatar
im pretty sure you got the wrong springs. I have them too but didnt install them yet. Im 99% sure there a direct replacement, thats why i bought them.
Old Feb 14, 2007 | 10:41 AM
Thats what I thought too. I got them off of Texas Speed they were the only dual vavle springs they had listed for the lt1 I think it said they were like 1.43 diameter though. I didnt know the actual stock spring diameter so i think that is the problem.
Old Feb 14, 2007 | 10:54 AM
porksoda's Avatar
You need the matching seats. Let me hunt down my part numbers real quick...
Old Feb 14, 2007 | 10:59 AM
porksoda's Avatar
Here is what I used
CC503 cam
1305-16 CC Pro-Magnum Rockers 7/16" stud (1:6 ratio)
26918-16 CC Beehive Spring
795-16 CC Steel Retainers (LT1 for 918 springs)
611-16 CC 10 degree Lock (11/32 super lock)
134-7103 Arp (Rocker Arm Stud) 7/16"
14011051 GM Guide Plates
4705-16 seats
Old Feb 14, 2007 | 11:11 AM
Imnotfast's Avatar
26918 is not a dual spring. It is a Beehive spring
Old Feb 14, 2007 | 11:13 AM
Taubr Unit's Avatar
hey man, if you need locators i have them! as well as locks and retainers. For cheap!
There locators/10*locks and retainers for 918 springs.
Old Feb 14, 2007 | 12:33 PM
Thanks but the cam isnt big enough to need locks or anything like that.
Old Feb 14, 2007 | 12:43 PM
Taubr Unit's Avatar
but you need them to run the springs if you got behive springs. The cam has nothing to do with it.
Old Feb 14, 2007 | 12:55 PM
I thought the stock ones would work.
Old Feb 14, 2007 | 12:56 PM
How much do you want for all of it?
Old Feb 14, 2007 | 01:04 PM
seawolf06's Avatar
Look at your springs again. Is it only one spring coil or is it one smaller one inside of the other?
If it's two, then you don't have the 918 springs. If it's one, then you need the locators, locks and retainers. DO NOT reuse any of the stock valvetrain. You're likely to break something.
Old Feb 14, 2007 | 01:06 PM
Its definetly 2 springs. I think they are a little overkill for one thing and they dont fit for another.
Old Feb 14, 2007 | 01:10 PM
The cam that is going into the car is a 224/236 .538/.541 114 lsa. What exactly would you guys suggest as far as the valve train goes. The only reason I didnt get everything else is because Texas Speed told me I wouldnt need anything but springs and rods for this size cam.
Old Feb 14, 2007 | 02:27 PM
seawolf06's Avatar
Wow, I can't believe they sold you that telling you it would work. They are definitely NOT 918 beehive springs.
You MIGHT be able to use the stock stuff, but it's weak in comparison to the RIGHT parts.
I bet they sold you the cheap hardened pushrods too. That's a decent size cam.
Old Feb 14, 2007 | 02:51 PM
Taubr Unit's Avatar
hell yea, id return thoes and get beehives!
Old Feb 14, 2007 | 02:54 PM
Well I ordered the beehives and I am going to return the other springs. The pushrods are good though.
Old Feb 14, 2007 | 02:55 PM
The beehives where a lot more expensive though.
Old Feb 15, 2007 | 12:33 AM
seawolf06's Avatar
You get what you pay for. Did you get just the springs or the locks/retainers/locators as well? I know you can get the locks/retainers from Taubr and they're in perfect condition. You need the 10 degree +.050" locks for stock heads.
