No rear brakes??
Old Feb 15, 2007 | 06:19 PM
BOBMAJER07's Avatar
Default No rear brakes??
i just installed a 4.10 posi rearend from a 98-newer camaro into my 95 camaro....when i tried bleeding the brakes no fluid came out and now i only have front brakes and then pedal is very mushy till 1/2 way down when the front brakes kick in... also the ABS INOP light and BRAKE ane now on...well, the ABS INOP light has been on since i put the lt1 in...please help on what i should do?
Old Feb 15, 2007 | 06:44 PM
Enforcerws6's Avatar
If I had to guess I would say its like a problem I ran into with some older cars. The proportioning valve tripped and wont let the fluid past it to bleed it out. Can be a big pain in the ***. You may try getting one of the bleeder kits where you can pump the fluid out vs pushing the pedal but I dont think that would help if its what I think it is.
Old Feb 21, 2007 | 08:29 PM
BOBMAJER07's Avatar
anything else? anyone?
Old Feb 21, 2007 | 10:08 PM
ele-blue95's Avatar
Did you try running the car while you were bleeding brakes? That was the only way i could get the valve to open on mine. With the OBD1 cars that is the only way with out a tech tool. and that is how i bleed my brothers 94, my friends 93. So give that a shot and let me know.
Old Feb 21, 2007 | 10:51 PM
the_merv's Avatar
Veteran: Air Force
I have never had a problem bleeding the Brakes out on my Car, and I have done it a few times. I upgraded to the LS1 Brakes, that might be a difference..
Old Feb 22, 2007 | 12:32 PM
BOBMAJER07's Avatar
im pretty sure its an issue thats its because its a 98-newer rear end...but idk
and yes i tried bleeding the brakes with the car running and i got nothing
Old Feb 22, 2007 | 01:10 PM
01WS6/tamu's Avatar
master could have died crack the fitting on the master and step on it to see if you have flow. It is possible the master and abs unit are just full of air.
Old Feb 22, 2007 | 07:49 PM
BOBMAJER07's Avatar
the front brakes bleed fine..its when i try to do the rears when nothing happens
Old Mar 7, 2007 | 07:32 PM
BOBMAJER07's Avatar
...ttt
