Looking to build a 396.
Old Feb 20, 2007 | 08:11 PM
ele-blue95's Avatar
Default Looking to build a 396.
I want to build a 396, but have some questions. First, will a 396 be reliable to have as a daily driver? Second were is the best place to get the crank, rods, and pistions? Third, what kind of power can i hope to see out of the build with a good cam. I want the power band to be somewhere in the 2500 to 6500rpm range. I already have a transmission, driveshaft and rearend to hold 700 to 1000 RWHP. Any ideas would be great.
Old Feb 20, 2007 | 08:54 PM
96capricemgr's Avatar
Heads are the single biggest factor in making power and you left them out.
When I do a shortblock I probably will not go that big but I will most likely go with the Compstar Speedpack. Look at their site and you will see some familiar names under the distributors links.
Old Feb 20, 2007 | 11:03 PM
ele-blue95's Avatar
I will more than likely go with LE3 heads and cam. Just want to get some ideas, so i can get my money together.
Old Feb 20, 2007 | 11:51 PM
96slow6's Avatar
Lunati bottom end is the only way to go.
Old Feb 21, 2007 | 05:41 AM
LT1Falcon's Avatar
not trying to steal his thread, but whats the advantage of going with a 383 over a 396
Old Feb 21, 2007 | 06:03 AM
IllusionalTA's Avatar
less machine work involved, can use a reg. cam rather than a small base circle, etc...
Old Feb 21, 2007 | 09:39 AM
94Z396's Avatar
Are you going with a 2 bolt or 4 bolt main block! On my block i am using Oliver Billet Mains with ARP studs! If your going with Nitrous later I would stud it!
Old Feb 21, 2007 | 12:53 PM
ele-blue95's Avatar
I want to make a 2 bolt into a 4 bolt splayed.
Old Feb 24, 2007 | 02:23 AM
96slow6's Avatar
Why? When was the last time you saw a main cap fail? Never? Ya me neither.
Old Feb 24, 2007 | 11:54 AM
CougarL92's Avatar
396 = tq monster
