Problems Problems
Old Feb 21, 2007 | 10:06 AM
SSClone's Avatar
Default Problems Problems
Installed Nitrous Express kit on my car about a week or so and had some bad luck. Started out with a 100 shot to make sure everything was good, sprayed a few short runs and everything seemed fine. Later the same night i was driving stopped at a store for about 10 minutes letting the car idle while in the store, got back in and it was bucking, jerking, just running bad. Thought I filed out some plugs, so I changed them, new plug wires. I pulled one of the plugs last night and the tips were white. Does that mean anything? Need some help please!
Derrick
Old Feb 21, 2007 | 10:23 AM
WhyHelloOfficer's Avatar
Derrick
White plugs means you are leaning out.
Were the old plugs white? Or are the new ones white too? Have you had the car tuned or on a wideband before? Is it still running rough?
Drive around and see how the car is behaving on motor to make sure you didn't burn a valve with it leaning out. If it still feels okay -- then it sounds like you're going to get the car on a dyno and start jetting up on the fuel side so you can get a safe a/f on spray.
Old Feb 21, 2007 | 10:31 AM
SSClone's Avatar
The new one's are white. Just driving the car around , it still runs bad. Almost like a injector wasn't spaying or a plug not firing.
Old Feb 21, 2007 | 11:39 AM
koolaid_kid's Avatar
Have you checked your fuel pressure? I had a similar experience last year and it turned out that my FPR had kicked the bucket.
