harmonic balancer question
Old Feb 24, 2007 | 07:58 PM
eLTwerker's Avatar
Default harmonic balancer question
http://thunderracing.com/catalog/?ac...vid=4&pcid=112
I don't understand the concept behind this balancer. Does it bolt on to your underdrive pulley? I thought the ud pulley also acted as a balancer. Is the ATI Super Damper for high hp and rpm applications or something?
Also, what bolts are included in their balancer bolt kit(ARP). Just click on balancer bolts on the left side of the page if you don't know what I'm talking about. Does this include a crank bolt? What other bolts does it include?
Old Feb 24, 2007 | 08:34 PM
siniSSter's Avatar
It is a complete hub and balancer assembly. You will not be using the 2 peice hub assembly. Your exactly right, the balancer is intended for high rpm rotating assemblies. If you have a stroker, or shift at about 7 grand. This item is a must to prevent crank vibration.
Old Feb 24, 2007 | 08:45 PM
eLTwerker's Avatar
So the link I posted contains a pulley and balancer??
Old Feb 24, 2007 | 08:52 PM
siniSSter's Avatar
Yes, if you look at the product description on Thunder Racing is says Damper Assy with Hub.
Old Feb 24, 2007 | 09:08 PM
eLTwerker's Avatar
Oh, didn't know hub and pulley were the same thing. DOH!
Old Feb 24, 2007 | 09:10 PM
siniSSter's Avatar
Its OK, were all here for a learning experience. Glad to be of assistance.
Old Feb 24, 2007 | 09:35 PM
eLTwerker's Avatar
Wait a minute. It looks like a crank hub and balancer. Is it also used as your crank pulley? Some pulleys, like March, just piggy-back on your stock damper. Is this more like ASP, which is a pulley and balancer combined? However, this would be, then, a pulley, crank hub, and balancer all in one. It must not be underdrive, or else it would say so, right?
Old Feb 24, 2007 | 09:36 PM
siniSSter's Avatar
Yup its a whole in one deal now
Old Feb 24, 2007 | 09:56 PM
eLTwerker's Avatar
Thanks for the insight, much obliged!
Old Feb 24, 2007 | 10:58 PM
dhdenney's Avatar
My Fluidampr is the same way. Kinda of pain to do opti when you have to take the whole damn thing out. I miss the stock setup for that reason.
