View Poll Results: What is the best head for the money????????
AFR
34
26.36%
TFS
20
15.50%
Edelbrock
3
2.33%
stock ported
72
55.81%
Voters: 129. You may not vote on this poll
Originally Posted by GIGAPUNK
An extra 75 shot only gained him 0.05 seconds? What was his best on the 175?
Taller slicks, skinny front tires and QA-1's got that combo to go 11.6 to 11.7 on the 100 shot.
Originally Posted by onephatZ28
ported stock or cool. but if you are going to run a NOS I would go with the TFS heads
Nitrous likes compression, the Trickflows on a stock shortblock drop compression.
Those who try to use stock castings and have them ported by a reputable shop usually have pretty good results.
best results for the $$$$$ stock ported heads/intake with custom cam. Less than 2K. Will be in the 390's to 400 + RWHP with the supporting mods. I have 195 AFR's makeing good decent power, but like I said for the $$$$ Stock ported. Keep your compression high... you do not want to drop it... well at least not below stock, nitrous likes high compression as stated above
Advanced Induction (AI)
Lloyd Elliot (LE)
Port Pro's
have all been proven to make good ###
Lloyd Elliot (LE)
Port Pro's
Lloyd Elliot (LE)
Port Pro's
Lloyd Elliot (LE)
Port Pro's
--Alan
Originally Posted by 96capricemgr
Why?
Why?
The nitrous comment in their description I take to mean as a thicker deck for use on built nitrous motors like motors sniffing as much HP in just spray as your whole motor makes.
Swapping to them to run nitrous on a stock shortblock would be foolish. As was already covered nitrous likes compression and even with a thin gasket those will drop compression below stock on a stock shortblock.
ive got trickflows going on the 383 and they flow pretty good and im running 11:1 compression and im probably going to run 100 shot. hoping for 11s on motor and we'll see what the juice does.
#32
Trick Flow aluminum LT1 cylinder heads are designed for supercharged, nitrous, and stroker applications. They feature 195cc intake ports, 75cc exhaust ports, and 64cc combustion chambers. They are also good for a 600 lift cam. I dont Know what the stock lt1 heads are good for I think it is up to a 550 lift cam
For the money, stock ported heads and a good custom cam is hard to beat, throw some nitrous on top of that and you have a budget build that'll threaten 10's with the proper set up
#35
Originally Posted by blackcars
well i did the ebay thing and got a great set of afr 210 lt4 heads for $800. complete-so i wouldn't just look for brand new....
#36
Originally Posted by Camaro>Mustangs
thats wat i will do to. me buddy said afr is the fastest and i can run the edlbrock lt4 intake to match up.
#37
Anyway, plenty will have opinions but for a stock motor if you slap on a set of heads that lower your compression than you need to plan accordingly around the rest of the combo. Just saying your going to do heads/cam and nitrous doesn't end tha show.
#40
