air filter removal
Originally Posted by Lazlo
This should fit, goes right on the TB, maybe just drill a hole in the end for IAT sensor or just mount it on a bracket near it.
http://www.jegs.com/webapp/wcs/store...46165_-1_11175
Nice work man! If I HAD to drive a ford that would be the one though I might have gone a different way on the color.
thanks for the help but if you read about it, it says at the bottom: will not fit LT1
Originally Posted by GIZMO
I know of a couple of guys that run them. They cut the thermostat housing off the water pump and moved it.
Really? well i might consider it then. thanks
