elimintaing steam pipe ?s
got pics?
It is not some performance or emissions thing that could change over the years. Since the water enters the top of the motor and flows down air and steam would tend to get trapped in the highest point, which is the heads. The "steam pipe" is basically just a bleed to let air and steam escape without fighting gravity.
that was my understanding of the purpose of them
only for some guy to pull the engine out to do his upgrades and look at the part and ask himself "what the hell is this" only for his friend to tell him "Oh it's just added extra weight, go ahead and take it off cause you don't need it"
Basically, don't **** with it.
This pic shows a 92 Corvette water pump:
(for some reason the pump is upside down in both of these pics)
But you can see how there isn't any lower passenger's side hose barb installed in this model year of pump. On 93-97 F-bodies, this lower hose barb is the "outlet" port that runs to the heater core "inlet." The 92 Vette pumps didn't have this port because the "outlet" was the steam pipe.
I'm drilling the steam holes out to a 1/2" NPT size hole, (3/4" fitting), so I'm hoping that the added port and hose diameter will help scavenge heat from the heads more efficiently.
This is one way to "eliminate" the steam pipe.
. big mistake. and pictures of the 95-97 style steam pipe setups.
trying to get an idea before i buy one for mine. just want to see how its routed
i know that the earlyer style goes right into the radatior and the other to the TB.
http://shbox.com/1/tb_bypass.jpg
"throttle body bypass"
word, i want pics too
