Heating up on Highway
Old Mar 2, 2007 | 10:32 PM
LT1_King's Avatar
Default Heating up on Highway
my brother's car is a 94Z A4. it does good in town driving normal temp. but when we get on the highway at a steady speed his temp starts to climb slowly. it has coolant. his fans are working as well. his RPM's at 70 are about 2300 or so. well before i forget to mention he barely swaped his 2.73's to 3.73's. would this be a problem with the car to act like this?
Old Mar 2, 2007 | 10:55 PM
otherwhitemeat's Avatar
what water pump? some electric one don't work to well
Old Mar 2, 2007 | 11:01 PM
LT1_King's Avatar
it's the stock water pump. it's not electric.
Old Mar 2, 2007 | 11:14 PM
onebadbird96's Avatar
i have a problem like that but backwards from you i get on the highway at a steady speed the temp gos down around townit goes up hmmm? what the hell
Old Mar 2, 2007 | 11:24 PM
onephatZ28's Avatar
it sounds like the T-stat is stuck open. I would look at that 1st
Old Mar 2, 2007 | 11:25 PM
LT1_King's Avatar
you might want to check your fans. and the fuses to the fans. or the fans themselves. check your radiator cap and your thermostat. check your hoses as well.
Old Mar 2, 2007 | 11:35 PM
onephatZ28's Avatar
If the thermostat is stuck open, the water is going through the radiator too fast and does not have time to cool. If the water temp, comes down after you get off the highway, I would definately say it sounds like a stuck thermostat.
Old Mar 2, 2007 | 11:46 PM
BizZzatch350's Avatar
Moderator
Doesnt really sound like fans would be the problem, the rearson you hear this problem in reverse is because when the cars moving on the highway, the air dam diverts enough air in to the radiator to keep the car cool. When it gets in traffic, no air flow and it over heats due to fan problem. His car doesnt get hot in town, only when moving which is really weird.
LT1_King's Avatar
i've already put a stock replacement thermostat twice. would it be the waterpump itself? i need to take a real close look at it tommorow in the day time.
Old Mar 2, 2007 | 11:52 PM
onephatZ28's Avatar
****....it could be the pump.
Old Mar 3, 2007 | 01:17 PM
colts95ta's Avatar
I had this problem once and it turned out to be the air damn being ripped off and not deflecting air through the radiator but only on the highway because the fans kept it cool at low speeds. I was new to the f-bods then (bout 7 years ago) but thats what I found out. Hope this helps.
Old Mar 3, 2007 | 02:14 PM
LT1_King's Avatar
i'll take a close look at it in a little bit. it's my brothers car.
Old Mar 4, 2007 | 10:02 AM
Low N Slow's Avatar
Had the same symtoms on mine, it turned out to be a partially plugged radiator. Drop the fans and feel the radiator after it's warmed up good. Mine was only flowing thru about half of the radiator, the rest was cold to the touch.
Old Mar 4, 2007 | 11:10 AM
95Firehawk0158's Avatar
Same here. It would be ok around town but on the highway it would run too hot. My radiator was full of crap. Got a new one and it's all good now.
Old Mar 4, 2007 | 02:47 PM
Bill's 02 Z-28 SS's Avatar
After 40 MPH the fans will not kick in.
Old Mar 4, 2007 | 04:02 PM
colts95ta's Avatar
KINDA WEIRD THAT A RADIATOR WOULD JUST PLUG UP ONE DAY AND START GETTING HOT BUT i GUESS THATS POSSIBLE.
Old Mar 4, 2007 | 04:45 PM
daniel6718's Avatar
didnt read the thread, but the front air dam has to be there and not be bent dangeling or broken, or your car will heat up on the freeway
Old Mar 4, 2007 | 05:21 PM
Ironxcross's Avatar
if it is the t-stat, get the 160* one, you wont regret it.
Old Mar 5, 2007 | 08:11 PM
LTEA1's Avatar
hey just reading the thread my car does the same thing it runds good around town but on the highway doen about 75mph steady it heats up more than half way i got a new pump and a new 160*thermostat my fans are connected direct so they are on all the time also have the air deflector right any ideas of what it could be i heard it could be a minor blown head gasket i hope not its a rebuilt 355 about 6500 miles on it wuts the problem with the lt1s overheating?? anyone
