Oil pan gasket
Old Mar 4, 2007 | 10:27 PM
themadspoon's Avatar
Default Oil pan gasket
Is it possible to change the oil pan gasket with the motor in the car? If so how?
Old Mar 4, 2007 | 11:01 PM
Gun5's Avatar
gotta get the motor off the mounts i believe
Old Mar 4, 2007 | 11:19 PM
BizZzatch350's Avatar
Moderator
It would be a a complete bitch to do! But if you got the motor off the mounts, jacked it up you may have enough room to drop the pan and get the gasket on. Never done it with a motor in the car, lot easier on the stand
Old Mar 5, 2007 | 12:11 AM
buffman's Avatar
I did it on my roadmaster. However I have a lot more room to pull the engine up. Now if you're just changing the gasket, you may not need as much room. I needed the extra room cause I put a nice powdercoated pan on while I was changing the gasket.
Old Mar 5, 2007 | 01:01 AM
the_merv's Avatar
Veteran: Air Force
That will be a fun project..
Old Mar 5, 2007 | 02:36 AM
skinnies's Avatar
We dropped the pan before to get the oil pump out, took about 5hrs total time in dropping it down(we let the kmember hang on the outter 6 bolts as low as we could, lifting the motor with a hoist off the mounts, getting the pump out, driving over to a buddies house to weld the pickup tube on the pump(BTW, Pauls little spot weld didn't hold the first time), then back to put the pump in, pan in, and button it all up. You shouldn't have a problem doing it.
Old Mar 5, 2007 | 02:43 AM
Revelation Z28's Avatar
i gotta do that soon
