Busted a oil pan bolts...
Old Mar 6, 2007 | 03:19 PM
ckyconan2003's Avatar
Default Busted a oil pan bolts...
i put my oil pan on my BRAND new freakin' motor....and i dont know how tight they should be since i dont havea torque wrench. Well it still moved so, i kept turnign it until SNAP! The head broke off.....should i tap it and get the bolts out, or apply black RTV where the bolt had broken off to protect against leaks?
How do i fix this problem?
Old Mar 6, 2007 | 03:37 PM
HectorM52's Avatar
Yes, get the bolt out of the block. You should be able to remove the pan without problems to get at it, right? Just go get an easy-out from AutoZone or Advance and take care of the problem.
You should be able to find a similar bolt at a hardware store. If not, I'll send you one. I've got extras.
Old Mar 6, 2007 | 03:46 PM
I really need one of the bolts that go in the back of there if you have extras of those, i'd need an extra pm me if you want my address.
