lt4 hotcam
Old Mar 6, 2007 | 07:55 PM
lt1camarojoe's Avatar
Default lt4 hotcam
my car is in the shop now for head gasket replacement and i am also getting the lt4 hotcam installed anyone know what kind of hp gains i will get
Old Mar 7, 2007 | 06:07 AM
sssalah's Avatar
20-25 flywheel HP, maybe 40-50 with headers and a tune.
Old Mar 7, 2007 | 07:44 AM
ele-blue95's Avatar
I gained 73 RWHP with my hotcam, when i freshened up the block and installed the cam. Im still running stock heads. I also put 1.6 RR and a tune from (ION) at madz28.com and all supporting bolt-ons. I went 13.67 before the build and 12.48 spinning after the build.
Old Mar 7, 2007 | 08:22 AM
the_merv's Avatar
Veteran: Air Force
It's a small Cam but it gets the job done. Not too bad of a sound either, you will like it.
Old Mar 7, 2007 | 10:38 AM
ckyconan2003's Avatar
What can i expect?
LT4 Hotcam
1.6 Roller Rockers ( Comp Cam )
Pacesetter LT's ( no egr )
Madz28 tune
4.10 gears
Aluminum driveshaft
Motor has been turned into a 355 freshly rebuilt ( bored .030 )
I had 317 before the motor was removed.
Old Mar 7, 2007 | 10:40 AM
the_merv's Avatar
Veteran: Air Force
350-370RW #'s, something in that area.
Old Mar 7, 2007 | 11:00 AM
forogot to add, moroso CAI. All mods are in my sig.
Old Mar 7, 2007 | 10:21 PM
DroppedM6Z's Avatar
i think more like 330-350 with stock heads. I've seen auto's make 320 with a mail order tune. As always Ed Wright @ FastChip for the best tune out there.
Old Mar 7, 2007 | 11:17 PM
the_merv's Avatar
Veteran: Air Force
I have an A4 that got 336/335, and that's with a Port-Matching that I did. M6 probably get 350's.
Old Mar 17, 2007 | 01:22 PM
yaboiJ's Avatar
:bump::
Old Mar 17, 2007 | 10:17 PM
plaf713's Avatar
my motor has the hotcam in it and it sounds great. at first i thought it would be to small, but dont let other people on this forum tell you that this cam is sucks, because dollar for dollar it makes good power
Old Mar 18, 2007 | 12:23 AM
i just got it back and it sounds good and seems to run real strong any suggestions on good headers to go with it
Old Mar 18, 2007 | 01:07 AM
birdmaro's Avatar
hooker coated longtubes ftw
