Boost + XFI Cam?
Old Mar 7, 2007 | 07:36 PM
87Lt1Monte's Avatar
Default Boost + XFI Cam?
Would it be a complete waste of time to run about 6 psi from a S Trim on my motor with a Large XFI Cam XFI292 i believe.
Old Mar 8, 2007 | 08:33 AM
Fire67's Avatar
My cam's an XFI cam... 230,236; .571,.576; 114
The thing is that if you dont order the XFI cam directly from comp or at least someone who knows whats up, you'll get it on a 112lsa instead of the 114. The cam has to be ordered with the 114 lsa for boost.
Once the Aeromotive Eliminator gets here, we'll be dynoing this thing with the Procharger D1sc maxed out
Old Mar 8, 2007 | 11:45 AM
87Lt1Monte's Avatar
Hey its on a 113 LSA u think that would be OK?
Old Mar 8, 2007 | 12:29 PM
RealQuick's Avatar
It will be fine...
Old Mar 8, 2007 | 12:33 PM
87Lt1Monte's Avatar
My cam is larger it has 248 242 58x 57x 113.. You think it would make decent numbers w/ boost?
Old Mar 8, 2007 | 01:07 PM
RealQuick's Avatar
It wil make power just fine, but it may not be as efficient as a custom cam designed for your setup.
