Not an LT1 mod question, but I need help from an LT1 guy
Oh, and the steam coming from below the radiator is probabaly just water evaporating of fteh radiator as I'm sure you spilled some when you filled the radiator up.
Yes, it does. IIRC, the temp gauge goes to 260*, with midpoint being 210*. The reason it doesn't boil is because the coolant is under pressure, the greater the pressure, the higher the boiling point. The first fan or low speed will kick on at 226, the second or high speed at 235.
I'm just going to try and sell the car as is for like $3400 and let someone who's more into LT1s and working on them replace the gaskets and have a nice car.
Are you sure that what your seeing isn't normal warm up condensation? If you have a blown headgasket they tend to POUR out steam. Like a lot. A whole lot. Doubt thats what it is.
my fans will turn on but only if I jump the aldl or have the ac on. i have replaced the temp sensor in the head and water pump. any ideas 94 formy
