Lt-1 Dud.
Old Mar 10, 2007 | 05:22 PM
BanditParts's Avatar
Post Lt-1 Dud.
Please Help, Ive Tried Everyhting.ok Please Read, I Bought A 94 Formula Lt-1 6 Speed, Power Everyhting. It Has The Lt-4 Hot Car, Ported Polished, From Day On Eof Buying This Car, Ive Had Nothing But Nightmares, It Runs When Ever It Wants To, Ive Replaced The Opti,injectors,manafolds,its Been To 6 Shops, 2 In Florida, 4 In Indiana, Nobody Can Tell Me Whats Wrong With It. Before The Computer Got Stolen Out Of It At A Shop, It Would Cut Out When Ever, Just Die, Sometimes It Would Start Up Some Times It Would Take Time, But It Always Started Up 2 Minutes Or 2 Hours Or Days. Then The Pc Gets Stolen, I Get Another And Have It Reprogramed, And Now The Car Wont Fire To Fixt The First Problem, Im Tired Of Thowing Parts, Has Any Body Ever Had This Problem? Ive Replaced Just About Everything Now.
Old Mar 10, 2007 | 05:35 PM
Cole Train's Avatar
my guess is either a wiring problem or the relay's are kickin' out. Check all the fuses and relays. Turn the car on and listen if any are kickin' out. Get a wiring schematic of the car and check ALL the GROUNDS. The mess with a lot when they get loose or corroded. That's all i can do for ya, hopefully you get it fixed. ~Cole~
Old Mar 10, 2007 | 05:36 PM
thesoundandthefury's Avatar
When you had the new PCM reprogrammed, did you have the VATS disabled?
Old Mar 10, 2007 | 05:38 PM
im about to cut it up. how hard and where is a place to get a ressonable clutch, i got pissed and broke this one.
Old Mar 10, 2007 | 05:40 PM
i took it to pontiac to have it reprogramed, they said they were the only ones that could do it, the factory alarm is not in it, the kid took it out.
Old Mar 10, 2007 | 05:43 PM
all the shops that have had the car, have put it on the computer, its said to be an interminet ( sp 0 problem, some said it was the opti spart, im told it can be the key chip, im tired , ive had this car almost 3 years and put 1500 miles on it to date.
Old Mar 10, 2007 | 05:44 PM
Ironxcross's Avatar
All LT1s are duds.
Old Mar 10, 2007 | 05:47 PM
When you turn the key in the ignition, does it try to crank at all or is it completely dead?
Old Mar 10, 2007 | 05:59 PM
Cole Train's Avatar
yeah if it's the VATS(key chip) you can bypass it for about $10. Find out what key number you have, get the resistor value that the key is and wire it up. If you think it's the problem you have i can give you my links. I have a TON of info on it as i had the same problem with my VATS.
Old Mar 10, 2007 | 06:36 PM
LT1MAN's Avatar
Originally Posted by Ironxcross
All LT1s are duds.
my car aint no dud.
Old Mar 10, 2007 | 07:00 PM
Ironxcross's Avatar
Originally Posted by LT1MAN
my car aint no dud.
I'm kidding, calm yourself.
Old Mar 10, 2007 | 08:29 PM
koolaid_kid's Avatar
Yeah, mine's a dud too. It won't even break into the 10's on a stock block, turbo only.
Old Mar 11, 2007 | 08:04 PM
LT1MAN's Avatar
lol, now thats a dud, lol
Old Mar 11, 2007 | 09:06 PM
97blkz's Avatar
my car aint no dud.
+1 , I do not consider mine a dud either.
Old Mar 11, 2007 | 10:27 PM
jmill96Z's Avatar
That car must have been built on a Friday
