Timing chain for 94 z28?
Old Mar 10, 2007 | 07:41 PM
94blownz281's Avatar
Default Timing chain for 94 z28?
Okay i want to upgrade my stock timing chain. i'm keeping the stock waterpump and my opti is brand new and not going to upgrade to the 95 style opti or remove anything else.
so anyone knoe the part number for a Cloyes single stock style chain?
Old Mar 10, 2007 | 07:44 PM
i420tom's Avatar
what does psi-fmic mean?
Old Mar 10, 2007 | 07:47 PM
Boost and front mount intercooler.....
Old Mar 11, 2007 | 08:20 AM
the_merv's Avatar
Veteran: Air Force
I got the GMPP LT4 Extreme Duty Full Roller Set, got a good deal on it and threw it in. Haven't had a problem with it.
Old Mar 11, 2007 | 08:48 AM
thing is you a have 95 and a vented opti. i can't use a double roller unless i have a EP,newer opti,timing cover,and change out gears. so i'm not spending all that money for it. just looking for a good single roller.
Old Mar 11, 2007 | 10:23 AM
96capricemgr's Avatar
How many stock chains have you seen break?
Everybody loves to hate the stock timing sets but I see no reason for it.
That said I think Lunati makes what you are looking for.
Old Mar 11, 2007 | 12:00 PM
well i got rid of the stock chain/gears so i need a new one regaurdless now. i think i found the one your talking bout EXPENSIVE!! $200-$300 dollars unless i'm looking at the wrong ones?
Old Mar 11, 2007 | 12:49 PM
Summit LUN-93094 $188.39
I don't know what a stock unvented timing set runs but the vented is like $60-70 last I checked.
Old Mar 11, 2007 | 10:25 PM
yes exact one i found. but says for 93 being the last year?
Old Mar 12, 2007 | 01:07 AM
WhyHelloOfficer's Avatar
I put a new stock timing set on when I did my cam swap and I haven't had issues. I was in the same boat as you with my non-vented opti (which was fairly new).
Just go the factory replacement route from an online GM Parts Dealer and you'll be in good shape.
Old Mar 12, 2007 | 07:31 AM
i worry though since i'm using boost though..
Old Mar 12, 2007 | 09:31 AM
Like the guy above said -- have you ever heard of a factory timing set breaking? I've been running it for over two years on my cammed car, and the past 8 months with Nitrous and I haven't had any issues at all.
It sucks the options are limited for us non-vented guys
Old Mar 12, 2007 | 10:02 AM
KFK's Avatar
KFK
I bought the Lunati one and it looks just like a stocker. I don't know where the upgrade is?
Old Mar 12, 2007 | 10:12 AM
dhdenney's Avatar
I second the stock replacement. $40 was the ticket for me.
Old Mar 12, 2007 | 11:10 AM
nope have not come across any breaking timing chains. in the pic of the Lunati i can't see any difference either. sounds like i should just take all of your guys word and get a new stock one. plus my car never see's the track and will only be driven on the weekends or here and there. guess i should have not threw away my stock chain . oh well my dyno tune i got was the end of my stock motor because they had no clue what they were doing. so maybe the timing chain might have been made weaker who knows?
still like to see more responses on using the stock timing chain.
Old Mar 12, 2007 | 11:12 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I went with a Lunati chain, its a GM sprocket but Lunati chain, After taking my motor apart I had the same amount of slack as a stock chain, I was kinda suprised.
Old Mar 12, 2007 | 11:25 AM
hmm makes me lean towards the stock one....
Old Mar 12, 2007 | 11:47 AM
okay then i need a part number for the 1994 timing chain kit then from GM. thanks guys
Old Mar 12, 2007 | 09:32 PM
The catalogues get confused because in 94 the b-bodies got the vented opti but the f-bodies and Vette got the 93 style unvented. So when looking for a timing set consider looking yours up as a 93 to avoid confusion.
Old Mar 12, 2007 | 09:38 PM
10128346 -- '93 - '97 LT1 Crank Sprocket
10128349 -- '93 - '94 LT1 Cam Sprocket
10128485 -- '93 - '97 LT1 Timing Chain
