Putting Lt1 in my s10 have a few quesitons...
Hey guys putting a 94 lt1 into my 91 s10 and have a couple questions. THe guys on the s10 forums arnt much help... I am wanting to know a couple wiring questions, I am not worried about gauges, what is the main wires i need to know to get it powered up and running... on my truck I have the starter wire, power to the cab, hot coil wire sorted out? is this all I need? the ecu is a from a m6 car.
I am going to be using a full manual th350 trans, Can I use a stock camaro auto flexplate, and converter?????? thanks
You can probably use the Camaro flexplate, although it might have to be redrilled. You will need a TH350 specific converter. The 4L60E/700R4 converter will not work on a TH350.
