96-97 ss
LT4 HOT CAM...........218/228 112 LSA
stock LT4 CAM........203/210 115LSA
- The hood
- The intake airbox and ducting to utilize the hood scoop
- car was lowered 1.5 inches, I believe with eibach springs
- the spoiler
- SLP cat-back exhaust
- wheels
- SS badges and numbered plate inside
I'm not sure if the shifter was changed to something better in the SS like a hurst or not. I believe thats all the extras that you got with an SS vs. a Z28
One way(might have a dash plaque too?) to distinguish them is by popping the hood(red lt4 intake manifold), but they're 1 of 100 so chances are it's not one. Most of them are collectors cars.
Anyway, Nope, my springs and shocks are different now. I have moog cargo coils with edelbrock shocks in the rear for the stereo weight. The rear sits at a more stock height. Then, I have QA1 300lb. springs and 12way adjustable shocks on the front which are probably 1/2" to 1" higher than it was (almost cant tell). I opted to raise mine up a bit mainly for the said weight issue in the back and because I'm running an X-pipe setup and needed a little more clearance for the occasional speed bumps and driveways.
CCA-07-503 --- 224@ .503/ 230@ .510 (1.5RR)--- 112 LSA --- 1800-5800
*would be about .536 int / .544 exh with 1.6RR (I think I did that right)
LT4 Hot Cam --- 218@ .525/ 228@ .525 (1.6RR)--- 112 LSA --- 1800-5800 RPM
