Ran the caprice the other night
Old Mar 13, 2007 | 11:13 PM
Koll's Avatar
Default Ran the caprice the other night
First of all. I did nothing except remove the air filter (completly stock LT1. With a system in the trunk).
Not only that but the weigh in with me was
1994 Caprice LT1
4600 LBS!!!
Raceway Park
Englishtown, NJ
Temp : 40F
Relative Humidity : 0
Absolute Barometer : 30.33
First run
R/T ........ .499
60' .......... 2.281
330 ......... 6.459
1/8 .......... 9.935
MPH ....... 70.90
1000 ....... 12.910
1/4 ......... 15.439
MPH ....... 88.92
Second Run
R/T ........ .192
60' .......... 2.263
330 ......... 6.443
1/8 .......... 9.921
MPH ....... 70.78
1000 ....... 12.903
1/4 ......... 15.434
MPH ....... 88.93
Third and Final Run (let car cool down for an hour)
R/T ........ .307
60' .......... 2.179
330 ......... 6.278
1/8 .......... 9.699
MPH ....... 71.96
1000 ....... 12.635
1/4 ......... 15.137
MPH ....... 89.95
If I had the right tire pressure, the right ammount of gas, the right stalling and uncorked (unhooked before cats) the exhaust, I could probably pull a 14.7
I had about 20 gal. of gas. plus me (312 lbs) and the subwoofer system
heres a pic to show exactly how STOCK it is.
Old Mar 13, 2007 | 11:19 PM
Koll's Avatar
BTW since then I have removed home base. Next step is to remove the silencer right after the maf and then gut the airbox.
Old Mar 14, 2007 | 05:36 AM
LT1Falcon's Avatar
not bad for 4600 lbs! ur first 2 runs were consistent too
Old Mar 14, 2007 | 06:12 AM
Ntimid8r7's Avatar
How many miles you have on it?
Old Mar 14, 2007 | 06:46 AM
LT1MAN's Avatar
cool, not alot of folks out there running caprices. where can i get some of the those green hoses.
Old Mar 14, 2007 | 07:38 AM
theroad64's Avatar
Damn thats fast for the weight.
Old Mar 14, 2007 | 07:40 AM
Koll's Avatar
Its got 136,000 on it.
Its a 9C1 (police interceptor) that was never used in service.
Old Mar 14, 2007 | 07:41 AM
fergymoto's Avatar
Garden hose comes on 'em stock. Quick time for the weight for sure.
Old Mar 14, 2007 | 10:06 AM
Something's Avatar
Those times are actually pretty damn close to what a stock Caprice should run, and better than most I have seen. Good luck with the b-body though. I LOVE these cars, and would definately own one if it wasnt such a "hot" car.
Old Mar 14, 2007 | 11:16 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Not bad
Old Mar 14, 2007 | 12:19 PM
omaha stylee's Avatar
[QUOTE=Koll]BTW since then I have removed home base. QUOTE]
Thanks, I got a chuckle out of that.
Old Mar 14, 2007 | 12:27 PM
Ed Wright's Avatar
9-Second Club
Don't remember ever seeing zero humidity around here. That and 30.33 baro, that would be some killer air to run in.
Old Mar 14, 2007 | 12:47 PM
Rhedalert's Avatar
Cool man! I've always liked them B-bodies.
What does home base actually do, just keep the air flow quiet? Or is it just an engine cover?
Old Mar 14, 2007 | 02:20 PM
Ntimid8r7's Avatar
Home plate is an air baffle. Usually you remove 3rd base and Home plate and it really quickens throttle response. To do it easy and cheap you can take 2-90* pvc elbows for sewer and tape them together to replace 3rd base and also a valve cover breather fits right into the hole where home plate is. It'll cost about $10 to gain alot.
Old Mar 14, 2007 | 03:57 PM
Koll's Avatar
To remove home base, it cost me around 4 bucks. I took a PVC hose cap (the ones with the big square top) that was 2 1/2 inches.
For the third base, I dont know yet.
What they do is act as a silencer. It sucks tho cause when you are just idling, its filling with hot air that is unmetered. So when you gun it, you arent getting a true reading and plus its hot.
Old Mar 14, 2007 | 06:57 PM
Ntimid8r7's Avatar
I used a chrome Bow-Tie breather for mine until I bought the ram air kit for it. If you use the 3" 90* elbows they are an exact fit. the only PITA was getting the MAF boots to fit. Use electrical tape to mend them and paint it black. Like I said before it worked for me...
Old Mar 14, 2007 | 07:15 PM
transam5.7lt1's Avatar
Good numbers! Congrats!
Old Mar 14, 2007 | 10:37 PM
buffman's Avatar
good times..
Old Mar 14, 2007 | 11:07 PM
danhr's Avatar
a buddy of mine races his caprice...
he has a tune, true duals, 325 m/t tires, shocks, 52mm tb, weight reduction, 3.73 gears, and he runs 8.8's in the 1/8
good times, love the b-bodies.... i actually think I should have gotten one instead of my f-body
Old Mar 14, 2007 | 11:13 PM
buffman's Avatar
Sure he doesnt have more mods? 8.8 is decently fast, and with tires as wide as he runs, sounds like he's running a higher stall TC. Or he has a seriously weight reduced car :0
