Question for you LT1 guys....
Old Mar 18, 2007 | 02:56 AM
revtime's Avatar
Originally Posted by blk97z28
wait i have a 97 lt1 z28 i have no fist gear selector but i have 2:73 and the better guage cluster?
2.73 gears mandated lock out of first gear. period.
There possibly is a Z28 out there with the GU5 (3.23) and the lower MPH cluster, which means it did not come with Z rated tires.
Anything is possible. Not very probable that a performance axle ratio did not come with Z rated tires however.
Old Mar 18, 2007 | 06:49 AM
the_merv's Avatar
Veteran: Air Force
I have the 150 Speedo, and there is a peg on it, if you drew it out, it would be at 165-170ish, I don't know how accurate it is at that speed, only had it there once..
Old Mar 18, 2007 | 07:33 AM
SprayedLT1's Avatar
It's because you have 2.73 gears. Gear ratios have no impact on anything like the speedo.
All cars with 2.73 gears have the 1st gear lockout.
All cars with Z rated tires have the 155 mph speedo
Old Mar 18, 2007 | 08:39 AM
Feenix's Avatar
Originally Posted by SprayedLT1
Most M6 cars had 3.42, but have seen a couple with 3.23.
Those with 3.23 would be 93 m29 cars. 94+ came standard with 3.42 if it was an m6.
