gen1 head swap
Old Mar 17, 2007 | 06:28 PM
94Pontiac's Avatar
Default gen1 head swap
I have a set of brodix -8 heads with stahl exhaust ports, lying around, for gen 1 sbc, and I was wondering what its going to take to swap them on, when I rebuild the lt1. That is if its even worth it. I already did a search but dident come up with the info need. Thanks in advance
Old Mar 17, 2007 | 09:23 PM
LT1Falcon's Avatar
ive never compared a gen 1 and gen 2 head side by side but i always thought they were totally different.......what with reverse flow cooling and some other stuff... idk tho
Old Mar 18, 2007 | 05:59 PM
94Pontiac's Avatar
anyone what kind of machine work is involved? can I use the lt1 intake? http://www.brodix.com/heads/-8.html
Old Mar 19, 2007 | 12:41 PM
9C1'Stangkiller's Avatar
It can be done, in fact, I'm pretty sure it's been done on this board. IIRC, to have your heads drilled, tapped and whatever else needs to be done, it's $3-400. That said, people who go this route usually go with a single plane intake because they bolted on a killer set of heads and are now outflowing the LT1 intake. Your heads or intake could be modified to bolt up to each other but why bother? What kind of short block is this going on anyways?
Old Mar 19, 2007 | 08:13 PM
94Pontiac's Avatar
not sure yet on the short block. I am I will be building it up after this season. It will definately be a forged bottom end, nitrous or supercharged motor. I havent decided on solid or hyd roller cam.
Anyone know how much power those of those brodix heads well flow?
Old Mar 21, 2007 | 06:01 AM
IllusionalTA's Avatar
They peak at 240@.500 for some odd reason.. if they're just sitting on your shelf yea it would pay as it's a pretty nice jump from a stock casting.. a stock intake wouldn't hurt this head tooo much either.. as it's not moving crazy air.. but i'd def see about having them massaged a bit.. w/ some better parts.. it could be a decent head w/ minimal $$$$
Old Mar 21, 2007 | 09:09 AM
JUICED96Z
Guest
Posts: n/a
240@.500?????????? OUCH!!!!!!!!!!
Yeah my shop is doing my conversion for that price listed or less. Its more or less some drilling and welding.
I am ditching the factroy intake and going single plain. It will really let the heads breath.
Old Mar 21, 2007 | 07:11 PM
94Pontiac's Avatar
these are the heads, the thing is im not 100% on what heads they are. There are no identifying casting numbers that I could match up, I was just going by looks....anyone verify what heads they area, maybe theyre not even worth the swap?
Old Mar 22, 2007 | 06:59 PM
94Pontiac's Avatar
can anyone id the heads?
