Need help ASAP
Old Mar 17, 2007 | 08:54 PM
zyoul8er's Avatar
Default Need help ASAP
OK so i had my hood popped and i noticed that my balancer was wiggleing around so i took it off and needed to be replaced ...put a new one on and it wobbles so i took it off and started the car with just the front hub on the crank and it wiggles up and down slightly...so i removed the hub and there is no keyway .....isn't there supposed to be? I wanted to make sure the crank wasnt bent so i started the car with everything removed off the front and the crank looks to be turning straight and not bent. What is going on here. Should there be a keyway or is the hub bent or what? thanks
The car is a 95 firebird formula with the 350 lt1
Old Mar 17, 2007 | 09:51 PM
93z4me's Avatar
lt1 engines didnt use keyways . the right way to install the balancer is to find the arrow on the hub of the balancer. then the crank should be at #1's tdc and then install balancer with arrow at 12:00 position. thats the gm service manual instructions. not sure if thats the problem . but it wouldnt hurt to try .
Old Mar 17, 2007 | 11:52 PM
zyoul8er's Avatar
thanks ill try that
Old Mar 18, 2007 | 08:28 AM
zyoul8er's Avatar
sry... i know how to install the balancer onto the hub but i don't know how to install the hub to the crank.
Old Mar 18, 2007 | 09:46 AM
FlamingChicken's Avatar
you have to press it on. not too difficult but have fun
Old Mar 18, 2007 | 10:50 PM
93z4me's Avatar
get a balancer installer or rent one from parts store makes the install easyier. also a little oil on crank and balancer help a lot too.
