how much nitrous
Old Mar 19, 2007 | 10:12 AM
chameleongreen97ta's Avatar
Default how much nitrous
if you had a brand new LT1 with zero miles on it how big off a shot can you run safely without blowing it up
Old Mar 19, 2007 | 11:21 AM
BlackScreaminMachine's Avatar
Internet Mechanic
What safety mods you running, how old are the injectors and fuel pump, what size injectors.
General Answer: 150 shot
Reality: Is the car sound, I know the engine is, but what about the fuel system?
Old Mar 19, 2007 | 08:52 PM
96capricemgr's Avatar
I know of cars running 200+ on stock shortblocks. On stock as cast heads though you will probably stop going faster after 150-175hp jets the heads wont flow enough let more than that really work.
One b-body I know of ported iron heads XE 224/236 200+80 and ran 10.9 at 122mph, motor had been seeing 200+ for YEARS
Old Mar 19, 2007 | 08:56 PM
WhyHelloOfficer's Avatar
With your fuel system in good working order, you'll be able to run a 150 shot safely for quite a while. Just make sure you a/f is safe on a wideband before you start spraying the crap out of it. I've been running a 100 shot on my car for over a year and I only had one hiccup when it leaned out a little too much, but everything else has been fine.
It is a good rule of thumb to get a new in-tank pump (Racetronix/Walboro 255lph) and that'll be able to support any fuel you'll be needing for a 150 shot and up.
Just check and double check it all before you start spraying a lot, and your car will have many many bottles to be used in its future.
Old Mar 19, 2007 | 09:26 PM
onephatZ28's Avatar
150 shot on my car all day long...
Old Mar 19, 2007 | 09:27 PM
the kit i am buying is a wet 125 shot and i will probably only spray a couple times a week at most
Old Mar 19, 2007 | 10:20 PM
camzaro28's Avatar
I have put about 15 bottles of 150 shots through my motor. It still loves the bottle, but I took it off for the time being, going to run the new H/C setup N/A for a while then throw the bottle back on.
Just listen to everyone when they say to make sure the fuel is up to par. I have all the safety requirements and that is most likely why I havent had any issues.
GL with the kit
Old Mar 19, 2007 | 11:27 PM
onephatZ28's Avatar
What kit??? like NX, TNT ::::::::::::::::::::::
Old Mar 20, 2007 | 01:22 AM
it is a NX kit
