re-routed plug wires??
Old Mar 21, 2007 | 12:51 AM
undercoverz-28's Avatar
Default re-routed plug wires??
does anyone know where i can plug wires that re route from the originals to run from the opti and up over the valve covers then down to the plugs?
Old Mar 21, 2007 | 07:37 AM
LT1MAN's Avatar
thunder racing has the for $105, they used to be all over ebay i couldn't find any for you.
try these
http://www.thunderracing.com/catalog...vid=4&pcid=104
Old Mar 21, 2007 | 08:35 AM
WhyHelloOfficer's Avatar
I wouldn't get the Thunder Package -- I've heard some bad stories, along with personal experiences not really being great with Taylor wires.
I got a set of MSD 8.5s and moroso wirelooms (and some zip ties) and ran my wires over the valve covers. As long as you do it carefully and take your time, you'll be fine.
Old Mar 21, 2007 | 09:48 AM
the_merv's Avatar
Veteran: Air Force
You still have your A.I.R. stuff in that car?
Old Mar 21, 2007 | 10:23 AM
Some of it -- I just got lazy taking the rest of it out. It is all disabled, its basically just taking up space right now.
Old Mar 21, 2007 | 10:27 AM
LT1MAN's Avatar
yea i got some no name ones off ebay and they worked great.
Old Mar 21, 2007 | 10:34 AM
the_merv's Avatar
Veteran: Air Force
The Dremel helps with the cross-over pipe, that thing was a bitch..
Old Mar 21, 2007 | 11:53 AM
luckyou03's Avatar
I removed the AIR, but the routing should be similar. Wire lengths for thunderracing, 1. 29" _ 2. 30.5" _ 3. 33" _ 4. 33" _ 5. 37" _ 6. 41" _ 7. 41" _ 8. 40.5" As measured BETWEEN the boots.
Old Mar 21, 2007 | 12:01 PM
1SlowFormula's Avatar
That's exactly how mine are run...
