What about this cam?
Old Mar 23, 2007 | 09:26 PM
eLTwerker's Avatar
Default What about this cam?
A trusted name in the business recommended this cam for my application. Most of my mods are in sig. I'm more interested in ETs than dyno #s. Plus, I plan to stroke it out to 383 in the future. I wanted something to pull to at least 6200-6300. Car is not a dd. Just a track warrior and weekend toy. Qustions, comments, opinions: all welcome and very much appreciated. Thanks!
Cam recommendation: (350 LT4 with GTP Stage II heads, Vig 3600 converter)
236/242 .624/.576” 110LSA +4 advance (with 1.60 rocker arm)
Comp Cams XE/XE hydraulic roller lobes
3196S/3317S HR110LSA +4 advance (106 installed intake center @ .050)
Cam Valve Events 0.006 0.050 0.200
Intake Duration - ID 288 236 162 3196 XE lobe .624"
Exhaust Duration - ED 294 242 164 3317 XE lobe .576"
Lobe Center Angle - LSA 110 110 110
Intake Centerline - ICL 106 106 106
Intake Valve opens - IVO 38 12 -27.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC 70 44 4.5 ABDC
Exhaust Valve Opens - EVO 81 55 16 BBDC
Exhaust Valve Closes - EVC 33 7 -32 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 114 114 114
Overlap 71 19 -59.5 degrees
