valvetrain help
Old Mar 24, 2007 | 12:21 PM
chameleongreen97ta's Avatar
Default valvetrain help
I got a 383 ready to go in my car but i need to up grade some stuff. I am going to run a cc305. it has a .510 lift. I was wondering what lifters, pushods, and springs should i run.
Old Mar 24, 2007 | 12:42 PM
-PEPE-'s Avatar
You could go off a bunch of opinions in here, much of which is very experienced, but I'd recommend you call Crane or Comp and get the right combo from those guys, especially for a moderate cam like that. Is that less aggressive than the cc306? The 306 & GM847 are very very close profiles and have seen those run in 383's, but didn't even realize they made a 305, just curious.
Old Mar 24, 2007 | 01:11 PM
it has 220/230 at .50 lift so it is quite a bit smaller then those other two cams
Old Mar 24, 2007 | 02:45 PM
-PEPE-'s Avatar
damn dog...why not go with one of the others at least? You have a STROKER now man!!! The 847 or 306 would be baby cams in a stroker and the 305 sounds really small. NOt saying you need to go solid roller or anything ridiculous, just maybe little bigger than a 305 I would think since it's a fresh new build, start out thumpin good. Not knocking your build at all, it's awesome your stroked just think you'd be happier with a little bigger hyd cam on that 383.
Old Mar 24, 2007 | 02:59 PM
the cam came with the shortblock that i bought so it was not really my choice if it was it would of been a cc306 but i still might upgrade
Old Mar 24, 2007 | 10:40 PM
streetwarrior96's Avatar
Yeah dude go bigger. I messed up. I have the 230/236 dur .544/.555 lift on my 383, even though I am making good power I could be making a lot more.
