Oil Pump?
Old Mar 26, 2007 | 12:03 PM
1slowZ28's Avatar
Default Oil Pump?
Well, I've finally had time to start again on my 94 Camaro project. Just wondering what is the best oil pump I need for my 383 with a stock oil pan? Do I need a High Pressure/High Volume or can I just use the stock one. This is going to be a street car so don't know what is best. Any advice?
Yeah I did a search but won't work for me
Old Mar 26, 2007 | 12:38 PM
jmalibuss's Avatar
I would just go with a Melling M55HV High volume. Good reliable street pump. Be sure to get the matching pickup. Which is a a 55 S1 I beleive. You can use the stock one but if your in there it's cheap insurance. You will also need the upgraded oil pump drive #IS55E. This eliminates the plastic coupling sleeve and uses a metal one. All of these part numbers should also cross over to speed-pro so you can find them at most parts stores.
Old Mar 26, 2007 | 02:23 PM
1slowZ28's Avatar
Thanks man
Old Mar 26, 2007 | 09:26 PM
slamm69's Avatar
Better check into that m55hv melling pump.Mellings does not recommend that pump in any racing applications.They redesigned that pump and it is not very strong around the base.Your car might never see the track, I dont know,but why take the chance.Word is that if you leave hard it could brake right off at the base.Just call mellings they will verify it as the truth.There is even a small(too small)note that comes with the pump.Just trying to save you some trouble and money.Melling does sell a pump that will work but its a different part number and twice the price.
Old Mar 27, 2007 | 07:12 AM
sssalah's Avatar
You should use one of melling select series pumps the PN I think is 10553. This is a stronger pump unlike the normal with more material at the base. HV is not recomanded with stock size oil pan.
Old Mar 27, 2007 | 11:00 AM
foggedz's Avatar
Do not put a new mellings M55 pump on the car. It will break, and you could possibly blow your motor up. The new mellings M55 pumps are much weaker than the ones they produced a few years ago. I just installed a new mellings select, 10554 pump on my rebuild. This is the same pump mellings used to make, and sell under the M55 part number. They just claim now that its a "select" pump and raised the price $50.
Old Mar 27, 2007 | 11:05 AM
Nate81Camaro's Avatar
A few years ago I would have said Melling, hands down. Now, I'm not so sure. I'm not 100% positive if it applies to your application, but I'm guessing it does. Read why here:
http://www.nastyz28.com/forum/showthread.php?t=65870
Old Mar 27, 2007 | 02:16 PM
1slowZ28's Avatar
Damn....Thats intresting. Just ordered one from NAPA today,will have the check the thickness to see if it's true. Thanks for the heads up
Old Mar 27, 2007 | 07:58 PM
the_merv's Avatar
Veteran: Air Force
I have the standard Melling M155, haven't had a problem, it's strong..
Old Mar 27, 2007 | 11:20 PM
1slow - not a problem! Always happy to lend a helping post.
