Deleting TC
Old Mar 27, 2007 | 01:06 AM
95FbFormula's Avatar
Default Deleting TC
Can i just order a throttle cable for a non TC car to delete it. I would just like to get rid of the tc motor on the valve cover. Also i will be buying the SJM ABS delete and line lock kit how do I tell what type of breaks i have 3 or 4 channel
Old Mar 27, 2007 | 06:44 PM
beast69camaro's Avatar
Yes, you can just throw in a throttle cable for a non TC car. I did this a while back when deleting my cruise control and TC after the TC motor went bad. As a plus, the engine compartment looks much less cluttered as well!
From what I've read, a 3 channel rear only has one sensor on the differential/carrier housing and the reluctor ring is actually inside the pumpkin (I haven't actually checked it out myself, but I would guess you just look for a single harness/wire plugging in somewhere on the pumpkin). A 4 channel rear as an ABS sensor on the end of each axle tube, one for each wheel (in which case I assume you'd identify it as such by looking for a split harness/wire running to each rear wheel).
Hope that was helpful
-Josh
Old Mar 27, 2007 | 08:37 PM
hi officer's Avatar
if you have traction control its 4 channel. also look at the abs unit. if two lines go in and three lines out its 3 channel. two in and four out its 4 channel.
Old Mar 27, 2007 | 09:23 PM
jd783's Avatar
is there anyway to delete your traction control and keep your abs?
Old Mar 27, 2007 | 11:02 PM
Yes you just go get the lines for a non tc car the throttle and cruise if you want it.
Old Mar 28, 2007 | 09:52 AM
jd783's Avatar
thats what i thought but when i unplug the TC motor it turns of my abs. does someone know if you can put in a resistor on the plug so it thinks its hooked up?i know slp sells a part that reverses the switch (keeps it off until you turn it on)but i want to get rid of the stupid motor. sorry if im highjacking
Old Mar 28, 2007 | 10:31 PM
I learned something today...thx
