Factory Oil Cooler
Old Mar 27, 2007 | 04:55 PM
3pnt4maro's Avatar
Default Factory Oil Cooler???
I was wondering where i could find a factory oil cooler for my 95 z....i have seen some on ebay but noone can say for sure if they came off an lt1 from a camaro..i dont really wanna spend 150-200 on an aftermarket oil cooler...mine wont work cause i spun the bearing and it has all sorts of metal shavings in it and as far as i can see there is no way to clean the fins that run the coolant through. anyone know where to pick one up.
Old Mar 28, 2007 | 06:49 AM
3pnt4maro's Avatar
noone knows where to get one
Old Mar 28, 2007 | 08:11 AM
koolaid_kid's Avatar
Don't run the one you have, obviously. A trans cooler would also do, like a B&M. Best of luck.
Old Mar 28, 2007 | 09:02 AM
rob97ss's Avatar
You dont need one,most people remove them.The clogged oil cooler could have had something to do with the spun bearing.
Old Mar 28, 2007 | 03:07 PM
3pnt4maro's Avatar
no it got clogged from the main bearings being spun..after it spun it picked up a bunch of the metal...by not running it wont the oil get a lil too warm
Old Mar 28, 2007 | 07:22 PM
aboatguy's Avatar
Probably not.
LT1 corvettes don't come with an oil cooler, GM just used Mobile One instead.
Old Mar 29, 2007 | 01:32 AM
3pnt4maro's Avatar
Originally Posted by aboatguy
Probably not.
thats interesting maube i will just leave it out...and run a synthetic
Old Mar 29, 2007 | 04:46 PM
Imnotfast's Avatar
Auto Cycle Marine in troy, michigan. had a few of them left. Ask for Darren
Old Mar 29, 2007 | 05:36 PM
maybe2fast's Avatar
I have one if still needed
maybe2fast@gmail.com
Old Mar 29, 2007 | 08:11 PM
GMRACER13's Avatar
Mine got clogged up with metal from 2 spun rod bearings. I went 397 and took the damn thing off and haven't seen any negative effects. One positive is that you can put a taller oil filter on if you remove the cooler.
